Autor | Thema: master cylinder (Gelesen 2729 mal) | |||
Hello
I'm trying to solve the problem of my brake pedal goes all the way down to brake and the brake alarm is on. I reviewed the shoes and cylinder of wheels and have purged the brake fluid without result. I'm thinking of replacing the master cylinder, anyone know the volvo part number and if there are a Land Rover equivalence? thanks in advance Guillermo | ||||
Hi Guillermo,
if you put the brakeshoes complete to the drums (just for testing), is it still possible to press the pedal down to the floor. If yes, there is still air in the system. If no, the brakeshoes are to far away from the drums. Regards Uli | ||||
Thanks Uli
The brakeshoes are new, have approached the brakeshoes on all four wheels, squeezing until the wheel stops and dropping a bit . the brake is going to end the first time the second one works properly. if there is still air in the system I think I would have to change all the fluid. regards Guillermo | ||||
Which brake shoes have you used? LandRover?
Do you have with the second step full pressure and does it hold ? | ||||
yes, both brakeshoes and cylinder are landrover
1. Problem
The LandRover-Brakeshoes are not so thick as the TGB-Brakeshoes 2. Problem there ist any Air in the System | ||||
Thanks at both...
brakeshoes new and refill all brake fluid circuit.... im working Guillermo | ||||
... have you already opened the Scews (fitting the brakelines at the servo) on top of the Brakeservos to let the air out.
Hat jemand schon mal den HBZ mit einer Reibahle bearbeitet. Ich habe meinen HBZ mit Honsteinen bearbeitet, bekomme aber den Rostfraß an einigen Stellen nicht raus. Alternativ: Hat jemand einen HBZ oder eine Bezugsquelle außer Tatanka. Gruß Christian | ||||
Eventuell mit ner einstellbaren Maschienenreibahle versuchen. Dann kannste Dich in Ruhe rantasten.... Oder halt länger Honen (Selber noch nicht versucht) | ||||
...und dichten tut danach ja nur der O-Ring....ich würde mich mal nach Ersatz umhören. Frage doch mal den Dirk ( Guwolo ) hier an.
Dicht wird der HBZ auf jeden Fall. Ist nur die Frage für wie lange. Ich habe schon Hydraulikzylinder notinstandgesetzt, die sahen schlimmer aus. Gruß Christian | ||||
Und ich hab mittlerweile die Dichtsaetze da. Notfalls auch alle Teile einzeln erhältlich.....
