Autor | Thema: For sale (Gelesen 63452 mal) | |||
Am see in Russia, 6x6 und Sauna.
Jyty 6x6 motor ist kaputt, ok nach Thailand Toyota Kz1 TE motor zu kaufen, packieren wie kondom and nach Finnland schicken. Auto gear Aisin auch.
From auto gear we cut 10cm. Flanche from Volvo gear box and welding. Married together Toyota and Volvo.
[/img] | ||||
New alu tank. Auto gear not working and electric injektion pump bad working. Tooo many electrical wires to connect. No problem, back to Thailand and I got from race car expert mechanical and tuned pump.
Auto gear is working with shifter, its semi-automatic now. If you try to use auto gear from original gear shift, you have P,R,N, 1, ,3 and 4 but never 2. and that makes car very lazy. | ||||
Now I need D to drive forward and then shifter 1-4 gears. I can change gear up and down with full gas, no problem. Its like Honda Monkey.
[/img] | ||||
Rims are double betlocks
Volvo transfer box low gear ratio is 3,7 (original 2,25).
Manchmal ist Schnee einfach zu viel! | ||||
My hobbys earlier. All sold away
[/img] | ||||
Winter? | ||||
Its not so long, wheel base is same as TGB 20. We cut frame from front and back. | ||||
Some roads in Russia (not small off roads) driven by 6x6. I think together about 15...20 000km. [/img] | ||||
Proto suspension, good I think!
White UN Proto is very rear with Chevrolet V8 diesel and auto gearbox, not good too small for that truck. Some luxus, dashboard from Masi. [/img] | ||||
Jyty 6x6 there are two alternators and 3 batteries. Toyota start and stop 12V. All Volvo systems 24V. Importand is 24V for vinches, no heating problems.
[/img] | ||||
Sometimes go driver tells you to stop wiching and sometimes not. I was winching from left too long time and broke the body of winchs. No problem, my friend can use tig and working again! [/img] | ||||
1/2 autom. line for betlock rims and widening. | ||||
Letzte Offi Auto für lange Fahrten.
Eine lange Geschichte. https://forums.offipalsta.com/showthread.php?t=150119 | ||||
Russland beschützte zusammen mehr als zehn Millionen Hektar. In der Kola Halbinsel Hiipinä Tunturi ist ein geschütztes Gebiet. Ich habe dort schon zweimal gefahren und es scheint, verboten zu werden. Es tut mir leid! Lezte mal mit Toyota. https://youtu.be/11mF_6Q3vmQ https://youtu.be/arbd8kepjP4 https://youtu.be/DBKErv8HAcg https://youtu.be/IGHdFPrY21U | ||||
