Autor | Thema: Mastervolt Chargemaster 24/80-3 / 24 Volt - 80 Ampere - 3 Ausgaenge (Gelesen 943 mal) | |||
Zu verkaufen:
Neuwertiger Mastervolt Chargemaster 24/80-3. Lagerware, Reserve-Exemplar, weder benuetzt noch angeschlossen, Schuetzfolie noch am LCD-Display. Ohne original-Verpackung. 24 Volt, 80 Ampere, 3 Ausgaenge (1x max 80A, 2x max 10A). Einstellbar auf viele Arten Batterietypen, sogar Li-Ion(!). Masterbus-Kompatible, also optional ein weiteres Display am Armaturenbrett, mit Daten zum Ladevorgang & Zustand der Batterien. Kan auch als reines Netzteil verwendet werden, also ohne jegliche Batterie. Inklusiver Temperatur-Sensor. Hiesiger Neupreis 1400,- euro Specifications General specifications Nominal output voltage 24 V Total charge current 80 A at 28.8 V Number of battery outlets 3 Charge current second output 10 A Charge current third output 10 A Battery capacity range 160-800 Ah Nominal input voltage 120/230 V (90-265 V), 50/60 Hz AC connection connector strips Power supply mode yes Display/read-out LCD display Fastening mounting bracket (included) or 4x screw Dimensions, HxWxD 432 x 277 x 150 mm / 17.0 x 10.9 x 5.9 inch Weight 8 kg / 17.6 lb Approvals CE, ABYC A-31, SAE J1171/ISO 8846 ignition protected, RMRS, RRR Optional Quick Connect (OEM) version with WAGO 770-113 connector and 25 cm cable, product code 44020802 Technical specifications Charge characteristic IUoUo, automatic 3-step+ for gel/AGM/wet/Lithium Ion Charge voltage Bulk 28.8 V Charge voltage Absorption 28.5 V Absorption time 4 hours Charge voltage Float (wet batteries) 26.5 V Charge voltage Float (Gel/AGM batteries) 27.6 V Temperature compensation yes DC voltage compensation automatic Power consumption (DC side) < 5 mA Full load consumption (230 V AC) 2700 W Current Control function yes, through MasterBus Power factor control 0.98 Temperature range (ambient temp.) -25 °C to 60 °C, derating > 40 °C / -13 °F to 140 °F Cooling vario fan Protection degree IP23 Protections over temperature, over load, short circuit, high/low battery voltage MasterBus compatible yes Charger Status Interface (alarm contact) yes, using a Multipurpose Contact Output (code 77030500) | ||||
Immer noch zu haben....;))
