Autor | Thema: Bin ja nicht leicht in die 'Off-Topic' Sparte zu locken.... (Gelesen 977 mal) | |||
....aber dieser passte nun wirklich nirgenwo sonst hin....:)
Also, endlich mal eine Anwendung entdeckt wo Ve-Tsin/Glutamat/Ajinomoto/E621 wirklich (wissenschaftlich bewiesen) negative Effekte hat....:)) https://www.researchgate.net/publication/333563832_Food_Additives_as_Factor_of_Corrosion_of_Mild_Steel_in_Neutral_Solution Abstract and Figures It has been showed that food additives E451 and E459 inhibit corrosion in neutral water-salt medium and additives E316, E631, E621, E631+E551, herbs and spices increased it up to 1.75 times. Under microbial corrosion condition, inducted by sulfate-reducing bacteria, inhibition action (up to 80.9%) was discovered only for additive E459. Other studied additives increased microbial corrosion up to 2.27 times. The presence of food additives in corrosive medium influences the quantity of sulfate-reducing bacteria in biofilm on steel surface. © Bondar O., Vorobyova V., Skiba M., Kurmakova I., Demchenko N., Chygyrynets O., 2019. Willem (war nur (und bin immer noch) suchende nach ein weiteres Derivat, dass die Wirkung von E621 verzehnfachen soll (scheint entweder E631 oder E635{*} zu sein, aber immer wieder andere Zahlen, nix Schluessiges)) Jan {*} https://en.wikipedia.org/wiki/Disodium_ribonucleotides (1:50 (2:98) macht 4x....also rechnerisch 200x?....8-)) + https://books.google.nl/books?id=khoGZWEAdy4C&pg=PA10&lpg=PA10&dq=e621+10+times+stronger&source=bl&ots=rTJz0iKp6j&sig=ACfU3U3-56TNM90D_kCbFGDX8cPNVGqegw&hl=en&sa=X&ved=2ahUKEwjP6auRtez0AhXQDOwKHdK1Bs8Q6AF6BAgSEAM#v=onepage&q=e621%2010%20times%20stronger&f=false (8-fach Verstaerkung) | ||||
