  11.August 2026 11:37:14
   Autor    Thema: ed.egidijus.kasiulevicius@gmail.com  (Gelesen 105 mal)
Ed
Einträge: 7
« am: 4.Juli 2026 11:12:0 »
WANTED: Rear Axle Differential Housing (Pumpkin) for Volvo TL11/TGB
I am currently performing a systemic restoration of a Volvo TL11 (TGB). My drivetrain currently has a "Null-State" status due to a missing rear differential housing (axle block).
I am looking to acquire the correct housing to restore systemic equilibrium to the drive system.
Technical Requirements:
Model: Volvo TL11 / C303 series portal axle housing.
Crucial Constraint: The internal gear ratio must be verified. (My front axle is [INSERT RATIO HERE – e.g., 5.99:1]. I require the rear housing to match this precisely to prevent transfer case decoupling/failure.)
Configuration: Must have the internal mounts for the vacuum-actuated differential locks.
Condition: Must be structurally sound, with intact mounting flanges (no cracks/structural fatigue).
I am prepared to arrange pallet freight from your location to Lithuania. If you have a parts truck or a spare housing, please reply with the serial number stamped on the housing so I can verify the gear ratio.
Any leads on dormant nodes or specialist dismantlers in the EU/Scandinavia region would also be greatly appreciated.
Seite erstellt in 0.0451 Sekunden. 19 Queries.
