| Michaels-Volvo-Offroader-Forum | SUCHE & BIETE | Gesuche / requests | « vorheriges Thema folgendes Thema » |
Thema: WANTED: Rear Axle Differential Housing (Pumpkin) for Volvo TL11/TGB (Gelesen 442 mal) | |||
Egidijus Kasiulevicius <ed.egidijus.kasiulevicius@gmail.com> 1:54?PM (17 minutes ago) to me WANTED: Rear Axle Differential Housing (Pumpkin) for Volvo TL11/TGB I am currently performing a systemic restoration of a Volvo TL11 (TGB). My drivetrain currently has a "Null-State" status due to a missing rear differential housing (axle block). I am looking to acquire the correct housing to restore systemic equilibrium to the drive system. Technical Requirements: Model: Volvo TL11 / C303 series portal axle housing. Crucial Constraint: The internal gear ratio must be verified. (My front axle is [INSERT RATIO HERE – e.g., 5.99:1]. I require the rear housing to match this precisely to prevent transfer case decoupling/failure.) Configuration: Must have the internal mounts for the vacuum-actuated differential locks. Condition: Must be structurally sound, with intact mounting flanges (no cracks/structural fatigue). I am prepared to arrange pallet freight from your location to Lithuania. If you have a parts truck or a spare housing, please reply with the serial number stamped on the housing so I can verify the gear ratio. Any leads on dormant nodes or specialist dismantlers in the EU/Scandinavia region would also be greatly appreciated. ed.egidijus.kasiulevicius@gmail.com | ||||
Gespeichert
