Autor | Thema: Welches Fett für Scheibenwischermotoren? (Gelesen 652 mal) | |||
Hallo zusammen, parallel zu den anderen Arbeiten steht die Sanierung meiner SWM an. Die arbeiten zwar einwandfrei, aber doch schon laut, und das Fett darin dürfte noch das originale sein. Ich will die nun neu machen. Die Frage ist: Was für ein Fett verwende ich? Bzw. was habt ihr verwendet?
I used Loctite Superlube synthetic grease, one 85g tube is more than enough.
I made new gaskets myself using a sheet of gasket paper, a scalpel and some hole punches. It was only later that I found they can be purchased here: https://iltisshop.be/wischersystem/dichtsatz-wischermotorp Maurice | ||||
Thank you. Did you also need the gaskets https://iltisshop.be/wischersystem/wischermotorgehausedichtung-neu?
I asked because some greases can attack some materials, as I learned, and the choice of greases is overwhelming. Ich habe gefragt, weil manche Fette manche Materialien angreifen können, und das Angebot an Fetten ist ja überwältigend. | ||||
No, I didn't need to replace the rubber outer cover gasket.
Here are some photos: One motor had water ingress, the other motor had dried up ancient grease, and for reference, here are my homemade gaskets. I chose synthetic grease as it should last longer than regular mineral grease, it has a suitable tempreature range (down to -40 or something like that), and it's waterproof. When reassembling the motor I first completely plugged the shaft tube with grease and then pushed the shaft through, the idea is to prevent water draining down the shaft into the first compartment. Maurice | ||||
