  20.Juli 2024 12:33:22
 Thema: Air filter housing 681607  (Gelesen 657 mal)
PaulB
Einträge: 14
« am: 25.März 2024 06:52:5 »
Hi - I am looking of an ai filter housing cover, if anyone can help? Thanks / thank you.
Mo
Einträge: 270
Re:Air filter housing 681607
« am: 25.März 2024 13:15:54 »
Einträge: 4855
« am: 25.März 2024 14:6:22 »
When repairing/renovating & sourcing major airfilter parts anyway:
Might as well upgrade to the later additional 'secondary' aluminium filterhousing modification.
Just to prevent any potential fire hazards (oily air filter icw backfire).
Some Volvo's burned to the ground because of this.
(after engine switch-off, walking away from parked vehicle, no supervision)
At one time (previous location, 1-2 decades ago), Tatanka had a (just as small) neighbouring shop that was once responsible for the entire batch of these alu filter housings for the Swedish military.
At least that is where I got mine from....
(today there must be plenty more sourceable second hand from otherwise cannibalised Volvo's (military only, AFAIK), but Tatanka might still be a good source for both versions....
Btw, I once also saw a (-n even later TGB20) version with (manually?) regulated air valves (I think) in the surrounding air ducting, probably meant to route the intake air along the hot exhaust during cold startup startup.
PaulB
Einträge: 14
« am: 25.März 2024 15:31:4 »
Thanks very much for the source and info Maurice and WJM
. I have the secondary alloy filter housing, but original housing  is is missing its lid.
So if I understand this correctly I should put the paper filter in the alloy housing and leave the plastic housing empty?
Thanks again.
Einträge: 732
« am: 25.März 2024 15:34:22 »
Right, plastic empty, filter in alloy box.
Mo
Einträge: 270
« am: 25.März 2024 18:22:58 »
To be clear I suggest contacting that seller and asking about only the air filter housing. That listing has been on kleinanzeigen for some time now.
Mo
PaulB
Einträge: 14
« am: 26.März 2024 08:53:40 »
Thanks very much. I am finding that website very difficult to use from here in the UK - I cannot seem to register. I will keep trying.
PaulB
Einträge: 14
« am: 26.März 2024 10:12:16 »
It is not possible to register on the https://www.kleinanzeigen.de website in the UK.
I believe the Volvo part 680743 will fit. It is for a thinner air filter but the same length and width. As no filter will be fitted I this box on a C303 this will not be a problem. This was fitted to more cars including some 164, p1300, 140 and may be easier to find.
https://www.skandix.de/en/spare-parts/engine/fuel-mixture-formation/air-supply/lid-airfilter-housing/1035299/
I will report back as this may help someone else in the future.
« Letzte Änderung: 26.März 2024 10:23:50 von PaulB » Moderator benachrichtigen   Gespeichert
Mo
Einträge: 270
« am: 26.März 2024 14:3:7 »
Yes. Brexit undecided I didn't realise you're also in the UK. Someone here may be willing to help out.
I suspect that air filter housing is for dual SU rather than dual Stromberg carburettors. Definitely worth a try though if it's not too expensive.
BTW, have you asked Tatanka? They often have parts that aren't listed on their website.
Maurice
« Letzte Änderung: 26.März 2024 14:14:52 von Mo » Moderator benachrichtigen   Gespeichert
PaulB
Einträge: 14
« am: 26.März 2024 14:28:22 »
Good to know - thanks very much. I have just realised the chassis brackets for the engine mounts are also missing. It's an almost complete truck but the bits missing are very hard to find!
Einträge: 2785
« am: 26.März 2024 17:37:41 »
Hi Paul,
thats me: https://www.kleinanzeigen.de/s-anzeige/volvo-tgb-c303-teile-konvolut/2518899756-223-9351
I also have the engine mounts.
If you have a list or pictures, I can check if I have the parts.
PaulB
Einträge: 14
« am: 26.März 2024 18:20:0 »
Hi - it is great to hear from you! I have sent you a message.
Seite erstellt in 0.0428 Sekunden. 23 Queries.
