  13.September 2026 14:59:3
 Thema: Differentials not engaging  (Gelesen 635 mal)
Lucagoesoffroad
Einträge: 6
« am: 23.Juli 2025 09:23:42 »
Hello! A garage disconnected some pipes during a repair and now the front differential and rear differential are not engaging anymore. The 4x4 on/off works perfectly, no vacuum leaks detected with the smoke test, but somehow the differentials don't work anymore, and I don't hear any PFFFFFF when I turn the diff switches on and off.
Does anyone have a schematic of the pipes connections? are there any valves that I need to check? Thank you very much
Einträge: 2862
Re:Differentials not engaging
« am: 23.Juli 2025 10:58:28 »
Hello,
the Switch in the lower dashboard is the valve.
Just follow the pipes from the switch and the differential.
I think there is just a connection missing.
Seite erstellt in 0.0578 Sekunden. 20 Queries.
