Autor | Thema: NATO Kupplung zulassen ohne Einschränkungen! (Gelesen 5245 mal) | |||
moin,
das leidige thema natokupplung als rangierkupplung hat wohl jeder satt. hier (Beitrag von Horni, 30.08.05 9:51) hat ein landy-fahrer in mannheim seine Nato kupplung und den trailer als vollwertige kupplung eingetragen bzw zugelassen bekommen. vielleicht ist der tüv dort mal einen blick wert... @viktor: vielleicht ist das der, von dem wir schon vorhin geredet haben?! grüsse, christian | ||||
Chris,
I have had numerous conversations concerning the NATO Hitch on various Web Sites. I have had a NATO Hitch on many of my off road vehicles and there are more than a few poeple in GB with them attached to various Landrovers. In my view the NATO Hitch should be the only one that is ever used because it is so safe and also strong. They can be set up to allow full articulation if the ring of the trailer is stationary though many trailer rings swivel in any case. This would allow the towing vehicle Landrover of what ever to remain safe even if the trailer capsized. The Dixon Bate NATO Hitch, there are several different sizes, is TUV Certified. I would have thought that this should be enough to satisfy the authorities in Germany. However a friend on Robi's Pinzgauer whom I was in conversation with in a thread, led me to believe that this might not be the case as the German Authorities are not that strait forward or simple and that one can not assume anything sensible. http://www.dixonbate.co.uk/Towing/pintles.asp This one is the most suitable I think, http://www.dixonbate.co.uk/towing/product.asp?PartNo=FV987958 | ||||
Grüße Anthony GB
thats exactly it. we have one- everyone uses it, but: the tüv doesnt want to put it in the papers. i'd rather use the original one than switching to another vendor. it was just that someone managed it to get it in the papers...i'll try in mannheim, sooner or later
Laut WIKIPEDIA (http://de.wikipedia.org/wiki/Anh%C3%A4ngerkupplung#NATO-Kupplung) ist eine NATO-Kupplung immer noch zivil ohne Einschränkungen eintragbar, insofern sie automatisch schließend sind und ein Prüfzeichen tragan: Nachtel: Das Auge/die Öse des Hängers muss offensichtlich größer als bei normalen LKW-Hängern sein.
Ich habe mal folgendes gesehen: Kombination aus LKW-Automatischer Kupplung und 50mm-Kupplung. Und das sogar mit Prüfzeichen. Gab es mal sogar bei einem Opel-Vivaro. Ob das teil noch gibt? Keine Ahnung. Wäre aber sicher interessant: Wohnwagen ziehen, oder mal schnell den Bauanhänger (bei uns im Ort auch den Toilettenwagen für Feste) | ||||
NATO ist halt eben groesser als Zivil (76mm; wobei Zivil auch 40 und sogar 30mm sein kann, in einige Laender). Zivil ist aber auch ein zylindrisches Loch, macht daher nur kleine Winkel mit, ausser um die Hoch-Achse, um ein 'ausbauchender' Bolzen herum; beim Nato hat der Ring-Duerschnitt eine zylindrische form (Toroidal), daher fast keine Winkel-Einschraenkungen. Uebrigens hatten die Russen/Ost-Staaten sogar 90 und 95mm Oesen, die hatten aber auch ein erheblich dickeren Ring, nur die wenigsten Klauen machen das mit. Hier mal ein ausgiebiger Uebersicht: http://www.markerink.org/WJM/HTML/tow_NATO-hitches.txt | ||||
