  5.März 2026 20:25:31
 Thema: Wiper motor parts / Wischermotorteile  (Gelesen 886 mal)
Mo
Einträge: 337
« am: 5.April 2023 10:31:20 »
Einträge: 4931
Re:Wiper motor parts / Wischermotorteile
« am: 5.April 2023 13:6:57 »
Not sure how compatible the entire VW Iltis wiper-assembly is (motor equal, geometry & outer bolt-pattern different? (there is no 100% match AFAIF)), but it also says 12v, not 24v....
(could very well be a mistake, since the Iltis only came in 24v originally, but those led astray towards 12v-conversion are probably even more abundant there than here, so this company might just cater to that part of the market)
So still good for civilian Volvo C3-series, but not military....unless at least some of the most crucial/wear-prone inner components are exchangeable, of course
(bearings, connectors, coal-brushes).
(at least the seals/gaskets can be had separately....;))
Mo
Einträge: 337
« am: 5.April 2023 14:14:3 »
My understanding is that the motor, gearbox and casing are identical, but the Iltis has 115 degree sweep angle while the Volvo has 85 degrees. So while it is physically compatible, it's not a direct replacement. Many parts are common to both versions though.
The 12V/24V situation is the same as our Volvos - military Iltis use 24V motors, civilian Iltis and the VW 181 use 12V.
Maurice
leoparker
Einträge: 28
« am: 26.Februar 2026 21:27:50 »
They are selling a wiper motor parts in his above post if anyone want this spare parts then this above post is for you.
Best Concrete Services in Fort Lauderdale FL
Seite erstellt in 0.0499 Sekunden. 21 Queries.
