Thema: Driveline gear noise (Gelesen 1320 mal)
BartG
Einträge: 19
New to the Volvo world
Driveline gear noise « am: 13.Januar 2022 10:45:13 »
Hello everyone,
I have a 303 which I am planning to rebuild over the next years but there is 1 main issue that I am not able to pin point.
When I drive in H the wining noise from the driveline (I think gearbox or transfer case) gets very noisy from about 40kph. The noise does not change when changing gear, its drive line speed related.
When I drive in L I get the same noise at much lower speeds. This would indicate the axles are not the blame. I now drive with the engine cover off to try help pin point the noise.
Is this the trasfer case with gears that are damaged? I also suspect the gearbox has issues because its hard to put into 1st and 2nd gear. I am in the netherlands and would love to meet a expert who can help open up the transfer case and replace the parts if need be.
Thank you for your comments.
Einträge: 4819
Re:Driveline gear noise « am: 13.Januar 2022 11:15:56 »
Hello everyone,
To locate the source, possibly even within gearbox/T-case you can either: - stationary / hoisted: put the tip of a long screwdriver to gearbox, handle to your ear - mobile /driving: attach (stiff) garden hoses(s) to each (side of the) component(s), metal pipe (closed tip?) connecting to case, and listen (or have someone else listen, in the back) Additionally/precursor: Is your front axle really disconnected normally? Cq does it noticeably/audibly engage (& disengage), by button, low-range shift and hard braking?
Those who wander are not necessarily lost J.R.R. Tolkien ...and not all who launder are washed/WJ....;))
BartG
Einträge: 19
Re:Driveline gear noise « am: 13.Januar 2022 15:28:7 »
Thank you for the comments. I will put it up on stands again to try the screw driver trick. It sounds like 2 straight cut gears that are eating each other up.
I did not notice the wine but this might be because there is no load on the gears when it is up on stands. I have not noticed any delays or hesitation in locking the transfercase to add front wheel drive. When it was on the stands a couple weeks ago, it connected and disconnected correctly.
Einträge: 2783
Re:Driveline gear noise « am: 13.Januar 2022 16:14:15 »
Does the noise change under load, can you influence the noise with the accelerator? If so, you may have too much bearing play in the VTG. Greetings Uli
Einträge: 1357
Re:Driveline gear noise « am: 13.Januar 2022 16:36:27 »
Remove the drive shaft to the front axle. Press the four wheel drive button and drive. Does the noise change?
Einträge: 705
Re:Driveline gear noise « am: 13.Januar 2022 17:8:25 »
Einträge: 4819
Re:Driveline gear noise « am: 13.Januar 2022 17:32:33 »
But do not engage 4wd in this ídle' configuration while driving! (as there is no RPM match between T-case & front axle/stub!) (hence grinding of the dog-clutch teeth)
Einträge: 4819
Re:Driveline gear noise « am: 13.Januar 2022 17:35:3 »
For low RPM, short duration, you could (have someone) pull the parking brake, to create the necessary load. (but only to the rear, front would still be no-load)
Einträge: 705
Re:Driveline gear noise « am: 13.Januar 2022 17:45:56 »
But DO engange the 4WD before driving, as breaking could engage it - with the same results.
Einträge: 1357
Re:Driveline gear noise « am: 13.Januar 2022 18:42:52 »
Ich bin ohne vordere Kardanwelle gefahren ohne Allrad. Da sollte man nur ganz, ganz vorsichtig Bremsen sonst hört man lautes Gerattere vom Verteilergetriebe. Ist nicht gesund. Also ALLRAD REIN Gruß Christian
BartG
Einträge: 19
Re:Driveline gear noise « am: 13.Januar 2022 19:3:8 »
Hi Uli, the noise only changes (gets louder) when the speed increases. If I depress the clutch, change gear, full throttle, the noise does not change unless the speed does. In Low range, the noise starts sooner which leads me to think its the transfer case.
BartG
Einträge: 19
Re:Driveline gear noise « am: 13.Januar 2022 19:4:29 »
This is also a good idea, I wanted to do this on the rear and run the car in front wheel drive, and do the same to the front. I will also have the shaft checked for balance which I have it off.
Einträge: 2783
Re:Driveline gear noise « am: 13.Januar 2022 19:9:50 »
OK, difficult. You should do like WJM said. Put it on stands and listen to the screwdriver. I use a stetoskop for mechanics to do those things. And be brave, you need some more rpm on the stands, not only idlings speed Good Luck Uli
BartG
Einträge: 19
Re:Driveline gear noise « am: 13.Januar 2022 19:17:47 »
Nice clips! I like the idea of recording it. I will try this on the weekend to see how similar it sounds to yours. I have no idea of the history of the car and I assume many things (like bearings) are worn or out of spec. But I am not technical enough to perform some of these jobs myself so I am not sure who to ask for help. Off course if its a shop I am willing to pay for the work, but I want to learn while they work on the parts.
Einträge: 1357
Re:Driveline gear noise « am: 13.Januar 2022 20:19:2 »
Sende a PN to hilledegroot, he ist from Netherland. My bei, he can Help you. There is also Arnold Talstra here in the forum Regards Christian
johnnyk
Einträge: 421
Re:Driveline gear noise « am: 14.Januar 2022 16:13:9 »
Are you able to get hold of a "Chassis Ear" It is an electronic listening device with up to 6 microphones embedded in clips. You can wire up to 6 points on the gearbox-- front and back -the diffs-portal axles etc. you listen to noise via headphones and switch between each microphone to find out where the noise is coming from. I used this device to find my Pto drive worn bearing on C304.
johnny
BartG
Einträge: 19
Re:Driveline gear noise « am: 14.Januar 2022 20:7:13 »
This is very interesting... I see they are quite cheap so it might be fun to get and use on other parts as well... Thanks for tip!
BartG
Einträge: 19
Re:Driveline gear noise « am: 16.Januar 2022 16:42:29 »
I have removed and checked the drive shaft, it is in good condition. The noise is exactly the same. I think its a bearing or gear inside of the transfer case. I hope these parts are available to replace because I dont want to change the whole transfer case.
