Thema: Viscous fan coupling (Gelesen 2288 mal)
Mo
Einträge: 248
Viscous fan coupling « am: 16.Februar 2022 13:35:14 »
A topic that has been covered before I know, but I coincidentally found this post at Facebook showing what seems to be a relatively simple and elegant modification to the mechanical fan. Image courtesy of Olaf Dressel. https://www.facebook.com/groups/174390316032333/posts/2216148618523149/He writes that "it needs a 60mm hole in center and 4 drills to adapt the visco. The original connector should swapped 180deg and planned". I don't understand the second sentence - any suggestions? I don't Facebook or I would ask directly Maurice
Einträge: 4819
Re:Viscous fan coupling « am: 16.Februar 2022 13:56:11 »
Planed, planiert, flattened, milled down?
Those who wander are not necessarily lost J.R.R. Tolkien ...and not all who launder are washed/WJ....;))
Mo
Einträge: 248
Re:Viscous fan coupling « am: 16.Februar 2022 14:55:56 »
Ah, OK, so it's not as simple as I first thought.
Thanks Maurice
Einträge: 558
Re:Viscous fan coupling « am: 16.Februar 2022 18:58:5 »
its easy peasy ... changing the fan parts needs 1/2 hour if you have the tools. i will bring one to our meeting with me in march ... By the way, Jörn additional made a conversion, while keepimg the outer roud steel frame and embedding an electric fan, its also already "Alpen approved" ... AND its easy possible to swap back, IF ... but you know while travelling
Mo
Einträge: 248
Re:Viscous fan coupling « am: 17.Februar 2022 10:21:15 »
Unfortunately I won't be able to join the March meeting, but I'm definitely interested to learn more.
Maurice
Re:Viscous fan coupling « am: 17.Februar 2022 10:50:3 »
Maurice
Where are you located?
Mo
Einträge: 248
Re:Viscous fan coupling « am: 17.Februar 2022 13:17:54 »
Northern England, near Newcastle upon Tyne
Re:Viscous fan coupling « am: 17.Februar 2022 14:3:3 »
A ok, a little far away
Einträge: 558
Re:Viscous fan coupling « am: 17.Februar 2022 14:36:29 »
No prob, we ve just finished the parts, i will made some img's to document. Its is REALLY easy going .. Rgds, Olaf
Mo
Einträge: 248
Re:Viscous fan coupling « am: 17.Februar 2022 17:51:1 »
Thank you very much
Mo
Einträge: 248
Re:Viscous fan coupling « am: 25.April 2022 20:11:4 »
I'm still interested to learn more about this...
Mo
Einträge: 248
Re:Viscous fan coupling « am: 23.Februar 2023 16:48:44 »
Dredging up an old topic but... Does anyone know if the 164 fan is compatible with the C30x? Maurice
Einträge: 705
Re:Viscous fan coupling « am: 24.Februar 2023 13:40:24 »
Einträge: 558
Re:Viscous fan coupling « am: 24.Februar 2023 16:54:7 »
blöd das man hier nicht vernünftig Bilder einfügen kann. Schick mir mal ne PN mit deiner email adresse
Mo
Einträge: 248
Re:Viscous fan coupling « am: 24.Februar 2023 17:18:57 »
Thanks, it's extremely unlikely that I would find that post using the search mechanism. My idea is to mount the B30 fan in the same place as the current non-viscous one, hoping that (a) I don't need to modify the existing flange and (b) it won't be so far forward that the fan blades are outside the protective frame. Thus you could easily swap back if preferred or required. If it's not the case, then I will follow the same path as KingCreole and OlliD. Maurice
