Thema: Valve cover gasket (Gelesen 1862 mal)
Mo
Einträge: 252
Valve cover gasket « am: 28.August 2022 18:54:32 »
Do I need a new valve cover gasket?
Re:Valve cover gasket « am: 29.August 2022 06:38:32 »
Do I need a new valave cover gasket?
obviously yes
Mo
Einträge: 252
Re:Valve cover gasket « am: 29.August 2022 09:5:51 »
Thanks. I've never had this problem before on a vehicle.
Einträge: 706
Re:Valve cover gasket « am: 29.August 2022 11:32:34 »
Don't overthighten the screws, that will ruin the sealing. Just hand tight is enough. And I put vaseline grease on the seal.
Einträge: 2799
Re:Valve cover gasket « am: 29.August 2022 11:59:44 »
Plan the holes in the cover, juse a new gasket und also gasket-seal (DIRKO).
Mo
Einträge: 252
Re:Valve cover gasket « am: 1.September 2022 17:9:27 »
Engine seemed really weak today, struggled with the slightest gradient. Checked underneath, saw what I thought was an oil leak but is in fact a coolant leak. Further investigation suggests it's coming from the valve cover. That suggests a blown head gasket, right? Maurice
Einträge: 7074
Re:Valve cover gasket « am: 2.September 2022 05:10:49 »
No Dirko at the Seal, only normal Grease
Slow-Rider
Einträge: 51
Re:Valve cover gasket « am: 2.September 2022 06:31:59 »
I would recommend to use the after market rubber seal with some normal grease instead of the original kork version - not so easy to install but works great.
Mo
Einträge: 252
Re:Valve cover gasket « am: 2.September 2022 10:23:16 »
Thanks guys. Unfortunately I have also blown the cylinder head gasket (or worse). The situation has become significantly more worrying
Einträge: 2783
Re:Valve cover gasket « am: 2.September 2022 12:7:54 »
...ist da vielleicht nicht nur der Kühlwassersensor undicht ?
Mo
Einträge: 252
Re:Valve cover gasket « am: 2.September 2022 21:34:43 »
I thought that too at first, but no, it's not leaking from the sensor. It will be towed to the garage on the 26th, then we will find out how serious the problem is Maurice
