  05.Oktober 2022 02:17:35
 Thema: Electric water pump  (Gelesen 155 mal)
Mo
Einträge: 171
Electric water pump
« am: 17.September 2022 12:05:33 »
I've been reading through the numerous cooling discussions here and a couple of posts caught my eye:
https://www.c303.de/c303-forum/index.php?board=1;action=display;threadid=14587;start=msg125323#msg125323
https://www.c303.de/c303-forum/index.php?board=1;action=display;threadid=14587;start=msg127295#msg127295
I don't plan to fit an electric fan, but I still think there's merit to use an electric pump to circulate water through the radiator after the ignition has been switched off. I have a few questions for those of you that have already fitted such pumps (not just Raffi and Christian wink):
  • How to you trigger the pump - manually or automatically?
  • How do you control the pump - temperature or time?
  • How long does it need to run (worst case)?
and I have a further question for those of you with electric fans
  • Have you considered completely replacing the mechanical water pump with an electric one?
Maurice
Einträge: 1216
Re:Electric water pump
« am: 17.September 2022 15:23:24 »
Hallo Maurice
Elektrik water pump in my Volvo is only running at ignition off. The pump is aditional to the mechanic pump. It is triggered by a timerelais for 10 min
Regards
« Letzte Änderung: 17.September 2022 15:25:27 von hecki28 » Moderator benachrichtigen   Gespeichert
Seite erstellt in 0.0422 Sekunden. 19 Queries.
