Autor | Thema: einstell probleme of the brakes (Gelesen 2029 mal) | |||
hello,
we have problems with einstelle/ adjusting of the brakes. we have put new soles on the brake pads. we found one landrover brake pad in our front wheel.. is this common? and in the other wheel probably one of volvo himself. and there were 3 springs in both front wheels and we did put back 2 of them, cause we heard it was not necessary to have 3 springs. is this true? and now the garage we went to says that the difference between right and left side is too big when we use the brake.. what to do? thanks!! djuleh | ||||
volvo c303 4x4 white painted and new window with diesel (Conversion kit for the OM603 diesel engine)
The break performance should not be dependent upon the number of springs inside the break drum. The spring do only ensure that the break pads are pulled back from the drum.
The breaks of the Volvo are a special case. First thing is that you need to ensure that you have good parts in your system. I.e. all cylinders are in good conditions, the break pads are OK and quite new. and that the drum is not too wide on the inside diameter. You should take break pads of the same type on both sides. Some Volvo break pads may be quite old (from the original stock of Volvo). LandRover parts do fit, please use the search funktion... Once you have all parts installed and the drum installed as well, then you have to ensure that there is no air in the system. Also some threads are covering this topic. A lot of bleeding is required to ensure that ! Then you need to turn the present screws on the inside of the wheel so that the pads are touching the drum. Once that is done you turn the pre-set screw 1/2 a turn back.. Make sure that the pads are used some time and a bit worn already (radius of the pads then match the radius of the drum). Then adjust the preset-screw again and then take your car to the technical inspection... | ||||
Thanks for your reply!!!
We are going to try this adjusting of the brakes¡!! We needed this info to make sure we are on the rightpath thanks!! | ||||
the wheel shoes are supposed to be connected to the brake anchor plate?!! isn 't it?!
thanks! djuleh | ||||
I found the answer allready thanks! It's a yes:-)
