  16.April 2024 19:39:40
 Thema: Brake 4wd activation  (Gelesen 1516 mal)
Dokatd
Einträge: 10
« am: 19.August 2018 19:25:29 »
Hi, I’m trying to figure out a problem and figured I would get the best answers here. I’m sure a search would find what I need, but I’m on a phone and can not translate to search.
Anyways, I am having an issue with my brakes where the automatic 4wd is engaging very early/easily.  Basically I cannot use the brakes without the 4wd kicking in.  I suspect that an alternate brake contact has been used or it could just be faulty.  Problem is I cannot verify for sure where this switch/contact is located.  Any help is greatly appreciated.
Einträge: 2783
Re:Brake 4wd activation
« am: 19.August 2018 19:38:35 »
...sitting in the Volvo its just in front of you in the brakeline under the dashboard.
Einträge: 2783
« am: 19.August 2018 19:44:28 »
Dokatd
Einträge: 10
« am: 19.August 2018 19:47:5 »
Awesome, I will track it down.
Dokatd
Einträge: 10
« am: 19.August 2018 19:49:47 »
Is there a spec or even a part number available that you know of?
Einträge: 2783
« am: 20.August 2018 18:8:34 »
...should be Nr. 44 Page 215 (Pressureswitch)
https://www.c303.de/c303-pdf/parts-list/PartCatalogue11.pdf
May be Tatanka has that.
Dokatd
Einträge: 10
« am: 21.August 2018 22:13:18 »
If they do it’s hidden.  Will have to email them.  I cleaned and readjusted everything and it’s certainly working better, but the 4wd still kicks in early.
Seite erstellt in 0.0528 Sekunden. 20 Queries.
