Autor | Thema: Brake 4wd activation (Gelesen 1505 mal) | |||
Hi, I’m trying to figure out a problem and figured I would get the best answers here. I’m sure a search would find what I need, but I’m on a phone and can not translate to search.
Anyways, I am having an issue with my brakes where the automatic 4wd is engaging very early/easily. Basically I cannot use the brakes without the 4wd kicking in. I suspect that an alternate brake contact has been used or it could just be faulty. Problem is I cannot verify for sure where this switch/contact is located. Any help is greatly appreciated. | ||||
...sitting in the Volvo its just in front of you in the brakeline under the dashboard.
Awesome, I will track it down.
Is there a spec or even a part number available that you know of?
...should be Nr. 44 Page 215 (Pressureswitch)
https://www.c303.de/c303-pdf/parts-list/PartCatalogue11.pdf May be Tatanka has that. | ||||
If they do it’s hidden. Will have to email them. I cleaned and readjusted everything and it’s certainly working better, but the 4wd still kicks in early.
