  18.Februar 2020 16:40:38
 Thema: Brake master cylinder replacement  (Gelesen 385 mal)
yitzac1990
Einträge: 47
« am: 18.Februar 2019 18:24:48 »
Hello,
Does anyone have any ideas for a brake master cylinder replacement?  Are there any easy master cylinders that will swap in place of the OEM Volvo C304 master cylinder?  I only found one OEM replacement from a swedish site and it was over $800!!!
yitzac1990
Einträge: 47
Re:Brake master cylinder replacement
« am: 30.April 2019 14:50:36 »
bumping this thread...we are still looking for a master cylinder replacement OR if there is a brake master cylinder rebuild kit, that works too.  we have 0 brake pressure, but we used a pressure bleeder and all the lines have fluid in them with no leaks...so we think the master cylinder is bad.
Einträge: 854
« am: 30.April 2019 19:03:44 »
Try to polish the inside of the zylinder with oil as I did. An issue kit you will get from Friese.
Regards
Brandonium
Einträge: 16
« am: 08.Mai 2019 22:38:48 »
I just rebuilt mine last week. Not sure it works as new since I have so many other brake issues at the moment. I ordered my rebuilt kit from Claas. The only issue I have with the rebuilt kits is that they should come with copper washers for the section where the flare nuts attach. Mine has a small weep from trying to re-use the old copper washers.
Definitely worth trying to rebuild. No way I would spend $900 on a replacement that requires remodeling. I'd go hydroboost first.
Seite erstellt in 0.0401 Sekunden. 20 Queries.
