Autor | Thema: Brake master cylinder replacement (Gelesen 1370 mal) | |||
Hello,
Does anyone have any ideas for a brake master cylinder replacement? Are there any easy master cylinders that will swap in place of the OEM Volvo C304 master cylinder? I only found one OEM replacement from a swedish site and it was over $800!!! | ||||
bumping this thread...we are still looking for a master cylinder replacement OR if there is a brake master cylinder rebuild kit, that works too. we have 0 brake pressure, but we used a pressure bleeder and all the lines have fluid in them with no leaks...so we think the master cylinder is bad.
Try to polish the inside of the zylinder with oil as I did. An issue kit you will get from Friese. Regards Christian | ||||
I just rebuilt mine last week. Not sure it works as new since I have so many other brake issues at the moment. I ordered my rebuilt kit from Claas. The only issue I have with the rebuilt kits is that they should come with copper washers for the section where the flare nuts attach. Mine has a small weep from trying to re-use the old copper washers.
Definitely worth trying to rebuild. No way I would spend $900 on a replacement that requires remodeling. I'd go hydroboost first. | ||||
