Autor | Thema: Headlight problem (Gelesen 1141 mal) | |||
I can't turn on my headlights via the blue switch.
I can turn on low beam using the auto dip switch (if the engine is running) and I can switch to high beam temporarily by pulling the turn signal lever under the steering wheel. (Tail lights activate via the blue switch as normal). Any suggestions? | ||||
Many thanks for clarifying the different possibilities. I hopt this will allow us to determine the root cause. Here are the test results:
PASS PASS FAIL When motor is running, low beam is on but cannot switch to high beam, can only flash.
PASS
FAIL When motor is running, low beam is off and cannot switch to high beam, can only flash. This suggests a problem with the blue switch (unlikely) or the "step relay" (stegrelä). Do you agree? Maurice | ||||
