  05.Oktober 2023 01:43:48
All-Posts
 Thema: Wire #47  (Gelesen 623 mal)
Mo
Einträge: 232
Wire #47
« am: 03.August 2022 17:14:41 »
Black wire, runs from the "Broms" light on the dashboard (grey and black wires share a single connector)
but is dangling free between the clutch and brake pedals.
There's a sensor of some kind mounted between the brake and clutch pedals, it has only one terminal. I assume this is where it's supposed to connect?
If you put your fingers behind the sensor you can push the shiny metal pin out, towards the driver. It can then be pushed back in, away from the driver.
Does anyone know what this is?
Maurice
« Letzte Änderung: 03.August 2022 17:28:48 von Mo » Moderator benachrichtigen   Gespeichert
Mo
Einträge: 232
Re:Wire #47
« am: 05.August 2022 17:51:03 »
Thanks, I wasn't sure what it was because it didn't seem to have any effect. This morning I discovered there was no bulb in the "Broms" warning light rolleyes
Maurice
Seite erstellt in 0.0588 Sekunden. 19 Queries.
