  18.August 2022 02:58:33
 Thema: Wire #47  (Gelesen 261 mal)
Mo
Einträge: 147
Wire #47
« am: 03.August 2022 17:14:41 »
Black wire, runs from the "Broms" light on the dashboard (grey and black wires share a single connector)
but is dangling free between the clutch and brake pedals.
There's a sensor of some kind mounted between the brake and clutch pedals, it has only one terminal. I assume this is where it's supposed to connect?
If you put your fingers behind the sensor you can push the shiny metal pin out, towards the driver. It can then be pushed back in, away from the driver.
Does anyone know what this is?
Maurice
« Letzte Änderung: 03.August 2022 17:28:48 von Mo » Moderator benachrichtigen   Gespeichert
Bär
Einträge: 145
Noch Neueinsteiger?
Re:Wire #47
« am: 04.August 2022 21:38:20 »
Hey Mo,
the sensor with the metal pin is the brake way sensor. If you can push your brake pedal to the ground the sensor is aktivated and the brakelight is on. If the sensor is aktiv, you can reset it with pushing to the driver.
When it is aktiv you have to check your brakes
Für Artgerechte Volvohaltung!
Mo
Einträge: 147
Re:Wire #47
« am: 05.August 2022 17:51:03 »
Thanks, I wasn't sure what it was because it didn't seem to have any effect. This morning I discovered there was no bulb in the "Broms" warning light rolleyes
Maurice
BritCarDriver
Einträge: 139
Re:Wire #47
« am: 06.August 2022 22:12:39 »
bare in mind: the pedal sensor is not the only activator for the broms light. The parking brake and the sensor for different brake fluid pressures in the two brake circuits will activate that warning light as well.
« Letzte Änderung: 06.August 2022 22:13:12 von BritCarDriver » Moderator benachrichtigen   Gespeichert
Seite erstellt in 0.0547 Sekunden. 21 Queries.
