Motor AUS .
Begonnen von der Harms, 2015-03-21, 08:59:42
Die Stirnräder solltest Du bei Jochen, Wagner und Günther und Tatanka bekommen...
Wechsel bei 100000 hört sich irgendwie gut an...für Bakelit-Dinger...die ich jetzt immer raus schmeißen würde. Die Stahl-Stirnräder-Schäden kenn ich nur aus hochgezüchteten Motoren...  ::)
johnnyk
Harms---- sorry to hear about your exploding Bakelite Cam driving gear in your B30E motor.
Although it makes more noise it is better to replace with Metal version instead of replacing with new Bakelite gear. "Been there done that" In other word Have experienced this Bakelite problem on other engines.
Are you enjoying the extra power from B30E what is your experience?
johnny
Christoph
Mr Harms is running this B30E engine in a 164 Volvo ... so you cant compare it... but he´s got a second Engine tuned up, but he has to wait for the engineswap until Superkarpatatrophy is finished!    ;D
We are not going to do enginetesting far away from civilisation in the rumanian forrests....
superkarpata starts in 41 days, lasts arround 6 days... getting back home... rest 1/2 day... rip of old engine 1/4 day...
this is the countdown for you to wait until the B30E can be tested
sorry Harmsi... ich wollte dir hier keinen druck machen, aber ich weiss das du es kaum abwarten kannst   8)
johnnyk
#18
Ohh I thought he had done it!!! When Harms does finally fit the B30E in C303 I am sure he is going to be very happy and show a big smile.  :)    To save him some fabrication time on exchanging throttle linkage, fuel return to petrol tank etc.  I have posted my B30E conversion a year or so ago on this forum which does not have all the details. He can contact me any time if he needs any ideas. I understand he has the same problem as me----- not enough time to keep wife and kids happy and spend time with"Swedish C303" girlfriend.    ;D
Allow more time for engine swap as it is the little things like wiring loom--where to mount computer and relays, throttle linkage and fuel return line that will take more than 1/2 day.
johnny
#19
Hi zusammen,
Bei mir gehts im Sommer 4 Wochen auf Tour. Das Stirnrad bereitet mir grübelei. Würdet ihr prophylaktisch aufschrauben und wechseln? Oder einfach Ersatz mitnehmen für alle Fälle?
Was brauch ich denn da alles? Das Stahlzahnrad, Dichtung für den Stirnraddeckel? Kurbelwellensimering?
Danke schon mal für Infos!
Raffael
#20
Hi die Angaben zum b30a Motor  besagt das es alle
100000 km getauscht werden sollte das stirnrad
Ist wie ein zahnrihmen  nur bis her  hab ich  nur einmal
Von einem Schaden gehört also alles gut
Gruß  der scaut
bezieht sich das nicht auf das Kunststoffzahnrad,
wenn die Stahl-variante verbaut ist, sollte das sich doch erledeigt haben.
Ja Kunststoff  das Metal  ist nicht Standart    :)
Habe ich bei meinem B 18 auch schon tauschen müssen.
Einige meiner Bekannten mit B18, 20, 30 brauchten schon neue Stirnräder.
Bei alten Motoren tritt der Fehler öfter auf....
Tausch ist keine Hexerei, aber beim Valp ohne Motorausbau werden die Arme immer länger...
Grüß Franz
Abzieher, und flüssige Dichtung  ....
Beim abziehen der vorderen Riemenscheibe aufpassen das der Halbmond nicht verloren geht....
Grüße küppi
...und beim Deckel die zwei unteren Schrauben nicht vergessen. Die Ölwanne wird da noch mit festgemacht.
Thomas
Das Problem mit Pertinax Stirnrädern haben auch alte Ford Modelle etc.
Wird halt irgendwann spröde, Öl und Hitze plus das Alter, kann schon mal kaputt gehen, Metall Stirnrad rein und Ruhe haben.
Hi zusammen,
Danke für die Infos. Ich werde das tauschen. Zwei Fragen habe ich noch:
1. ist die Anleitung hier prinzpiell OK oder? Bis auf das Kühlerabbauen das ist bei uns ja nicht notwendig
http://www.networksvolvoniacs.org/index.php/Stirnr%C3%A4der_erneuern_B18_/_B20_/_B30
2. wo habt ihr die Teile her und welche haben die beste Qualität? Passen die vom 164er? Was ist bei den beiden der Unterschied?  ???
https://shop.nordicar.com/de-de/volvo-parts/distributie-set-staal-origineel.html
https://shop.nordicar.com/de-de/volvo-parts/distributie-set.html
Danke schon mal und schönen Sonntag euch!
Lg Raffi
Der zweite sieht mir nach Kunststoff aus.
Du kannst auch mal bei Skandix schauen
Die haben auch einiges
Gruß  der scaut
