C304/OM603 build in USA
Begonnen von yitzac1990, 2019-02-12, 15:33:26
yitzac1990
Does anyone know if the C304 windshield wiper motors have some kind of relay or timer to make them work together in unison?  Or can they only be operated individually?  The previous owner of this C304 had each wiper on its own manual toggle switch.
yitzac1990
Havent gotten much noteable work done lately due to being busy with other stuff going on.  I got some heat wrap on the manifold to help cut down on heat in the "bay":
and also cleaned up the vacuum hose routing a bit and simplified it:
hopefully I can drop the fuel tank soon, empty it out, and get ready for diesel fuel and a return system added on.
gh-mobil
Hey Yitzac,
your project looks really interesting!
Does the length of the engine fit between gearbox and front axle without major modifications?
Does your om603 have the modified oil lubrication from the g-wagon with  for offroad use?
greetings and good luck!
- aktuell noch Fahrzeuglos, aber an einem c304 interessiert.
yitzac1990
Zitat von: gh-mobil in 2019-03-05, 05:22:44
Hey Yitzac,
Hello!  as far as I know it should fit fine.  There are some modifications that need to be made though, that include moving over the parking brake cable, moving over the OEM throttle cable, and relocating the alternator to the driver side of the engine.  Also, the right side motor mount needs to be cut off the frame, trimmed down, and moved back to clear the turbo.
i dont know about a modified oil system, can you provide any more info on this?  We are using modified OEM oil cooler lines and will eventually add in an oil cooler for extra cooling capability.
Thank you!
yitzac1990
#19
I got some more work done lately.  Installed an electronic speed sender (I started a thread with this information), made a block-off plate for the OEM fuel pump on the IP, and installed a loop for the oil cooler, just to get it running.  It will be changed out for an oil cooler system later on.
TGBwaldersee
Yitzac,
Many years ago, I was asked to install an OM603A into a TGB1314 utilizing the SMT conversion kit. Unfortunately, the motor supplied had major internal and external damage so the owner scrapped the idea and gave me the broken truck. I then installed an OM617A with good result. I have always wondered about how things might have been different had we gone forward with the OM603A swap after all.
I enjoy watching your progress. Where in the United States are you located? I am in rural NW Oregon and my wife, Emilie, and I host Northwest MogFest on our farm, "Waldersee" every August. This year will be our 20th annual event. All European high mobility vehicles are welcome and we expect at least a dozen Volvo C30X trucks at our 2019 event.
I wish you the very best on your conversion.
Take care.
Jim Molloy
Waldersee Farm
Sheridan, Oregon USA
http://www.northwestmogfest.com
yitzac1990
Good to hear from someone else in the US!  we are located in North Alabama.  Have you ever done the Gambler 500 up there?  I think we are going to try to make the one in Tennessee in September.  Sorry but I think Oregon is a bit too far from alabama, but it sounds like a great time!  If this c304 was mine, I would probably try putting a v8 in haha
yitzac1990
big milestone:  the engine is in!  well, sort of...  Since we upgraded the alternator to a GM alternator (which is most likely much bigger than a 1975 volvo alternator), there is VERY little clearance between it and the frame rail.  and the exhaust manifold also has very little clearance.  because of this, we are thinking of switching from rubber motor mounts to some custom solid mounts so the engine doesn't wiggle around and knock the alternator on the frame.  From these pictures, it is resting in its new home.  The trans/TC is bolted in place, but the front of the engine still needs to come up a bit before making final decisions on motor mounts.  in some areas, there are tons of room!  in other areas, things are coming very, very close.  overall it was a very tight squeeze but we got it in finally!
MarlonW
Looks very impressive! did you use the SMT-conversion set? was the engine with manual or automatic gearbox?
I didn't read all of your posts yet - sorry for stupid questions in this case..
yitzac1990
#24
Yes, the SMT kit was used.  some modifications had to be made still to accommodate everything, but so far it has worked out well.  This has a manual transmission...did they even make automatic transmission in these??  There is not much left to do to get it running....fuel lines, heater hoses, and some wiring!
kristaga
No, this is how they are supposed to work. They are powered by separate electromotors with separate relays and switches. Why should they work in unison? The only thing missing is an interval switch.
Me thinks the above could be construed to contain some confusion cq potential misunderstanding as to *which* engine (once) came with manual and/or automatic transmission....B30/Volvo(-general) versus C3-Series-specific (then also required to mate to the T-case) versus this Mercedes....
(which then still has this mating issue, apart from nearly always existing in both manual & automatic; both aspects make it unlikely this was your question about, but not without pondering & deduction....;))
NB: TTBOMK, in modern MB's, the last/strongest manual diesel came in the C320cdi....all else (both larger engines & series!) is default automatic.
(sadly I have no clue whatsoever to which other MB engines this gearbox also mates (which then would be at least a solution for transplants in G-wagen & Pinzgauer....:)) (having detached/separate/autonomous T-cases))
Willem (semantics rules the world) Jan
yitzac1990
so the engine is finally actually in.  we got some universal rubber engine mounts and got those installed a few nights ago.  also, got a lot of wiring done, and installed the key and switch panel!  The fuel pump and all fuel lines are installed, as well as fuel tank with new VDO level sender, and taillight wiring.  I need some large gauge ring terminals to finish up the battery to d-block wiring, and then start running wires to the fuse panel for other things like headlights, wipers, etc....
TGBwaldersee
I may have missed this previously but are your planning to continue to run the original 24v electrical components and use a separate 12v system for engine starting and management or going with an entire 12v system. If you do plan to go 12v completely, I am very interested in purchasing any and all of your 24v components.
Your conversion is shaping up quite nicely. Please keep the progress notes and photos coming.
Take care!
Jim Molloy
Waldersee Farm
Sheridan, Oregon
yitzac1990
when my buddy originally got the C304, it was already converted (sloppily) to 12v system.  so 1. we are keeping it all 12v and 2. he does not have any original 24v stuff.  sorry!!
I am completely re-wiring the entire thing to "start fresh".  We even made up a CID (cable interconnect diagram) of the entire vehicle to have on hand!
