Parabolic federn - wie viele möchte kaufen?
Begonnen von omega24v, 2008-09-23, 20:43:37
#15
Zitat von: ich in 2008-10-11, 11:36:24
There is one thing I don´t understand, Paul offers to buy the design and drawings: http://www.parabolicsuspension.com/designs.htm
that you can go to a local manufacturer.  With these informations he can make the springs without any problem. Why do we have to collect so many buyers? By the way I don´t like blue springs for my camouflage TGB but when I see the Verschränkung (in english??) and my poor frontsprings I´m convinced that I need 4 of them (two pairs, one set)
Well, first the 3-leaf package has not been tested yet in every possible application (even though apparently at least one person managed to assemble a 3-leaf set from the earlier 2-leaf protype batch (not sure whether that should give me hope for assembling a 4-leaf set myself)).
Second: apparently, there is only a handful of parabolic spring manufacturers on the entire planet....seems to be related to having the correct type of steel at hand, more than just the design/production expertise.
Vuko
Jan, I have a 3-leaf package since early 2007, I did 2 times the Superkarpata Trophy (1500 km on the street, 900 km hard offroad with 500 kg of equipment loaded), two times the ACS-Trophy, several trial competitions and austrian trophies. Never had any problem with it, so I can tell you, I have tested it in every possible application which exists from my point of view. My experience shows, that the C303 became very comfortable and has a much better axle articulation than before, no problems even with load, no problems with durability and stability. I dont get anything for giving positive feedback about Paul and parabolic suspensions, but I can tell you, I can recommend it without limitations. Which applications do you think, which are still not tested?
Kind regards
Vuko
Volvo Valp TGB11 C303 4x4iv "Snorre Gustavson" 4 expedition & trial  -- 4 Sale
Volvo Valp TGB1111A "Faxe" -- Now owned by Donar :-)
XJ 91 - dark red, slightly modified 4 girlfriend & trial R.I.P.
JK 2008
Es gibt keine Probleme, nur nicht gefundene Lösungen!
Kind regards
Vuko
Sorry, should have been more specific: in a LWB C306, with much higher front load (I estimate the C303 as 1500kg max, while a C306 is close to 2000kg, without any bells & whistles (rollcage, 2x 125L floor tank, possibly another 250L rear-cabin tank (or a lot of accumulated cargo + passengers in that area, also easily reaching 250-500kg), front-cabin mounted rooftent, etc etc.
So only rated at 2500kg I would be satisfied, for such a worst-case sample....:))
Btw, keep in mind that you tested the 2-leaf plus additional leaf (taken from another 2-leaf set I assume)....that is not necessarily the same as the current 3-leaf (if only because you must have cut off the secondary military-wrap for this 3rd layer, correct?)
(I believe Paul hasn't fully decided on whether or not the 3rd leaf will get its own military wrap as well (as it would conflict with the spring hanger, requiring too much space)).
That said: *if* the current 3-leaf set can be upgraded to 4-leafs just as easily as you did with yours, then it might get interesting....
Btw, the more I read about shock-absorbers in the context of very hard springs & compress/rebound ratio's, the more I become convinced that our rubber helper spring warrants a shock that is rebound-focused, just like the cross-reference analysis in Koni-context suggested (even though at least one guy at Koni thought it was madness....:))
(but he had never seen a Volvo either....;))
Vuko
Kind regards
Vuko
I see, sorry too, I missed that you want to place them in a C306! My setup is truly a two leaf setup with a third leaf added afterwards. The third leaf does not have the wrap you mentioned, it is only for covering the weight, the articulation is done by the two main leafs. Because of the missing space I cannot imagine the space for a 4 leaf setup with wraps, maybe I will make a photo today in the afternoon...
Of course the rubber helper spring is quite important, it nearly costs no articulation, but at hard bounces the shocks and the springs are supported. At the  beginning I wanted to remove them, but Iwan recommended to try it, he was right ;-) ...
Kind regards
Vuko
JK 2008
Vuko
For everyone interested, the part numbers on the Trailmaster shocks are 5775-2 and 20712012. They work fine with my 3-leaf setup.
@WJM
The problem you mentioned exists here (front):
The same at the non-shakle mount point of the rear leafs, here is no space for additional wraps...
Kind regards
Vuko
JK 2008
ich
Hello Erik,
hello all of you!
For a long time nothing happens in this thread, so I took a look at terrängbil.net. It looks like the projekt has died! The questiones which came up aren´t answered yet and I do not want to place a definite order when I don´t know the answers. When they are positively there will be my order for 4 springs for sure and I think some others as well! Whats the big difference to make 25 or 40 springs, when its possible to make Prototypes??
I wish you a merry good time:
Hans
never turn your back to mother earth
(dreh dein Auto nicht auf den Rücken)
