Problems with clutch and/or gearbox
Begonnen von Maarten, 2009-08-16, 15:08:16
Maarten
#15
Went to a couple of VW garages this week, 1 didn't have anything usefull (they seem to have new balljoint that could fit however). The other (a garage specialised in VW vans) told me that there are no VW vans that use these kind of rubber bushings, but they did have the plastic bushing that holds the ball in place (mine are yellow colored). They also told me that these bushing should contain grease and mine are completely dried out, so it probably shifts very hard and quite a lot power is needed to move the mechanism around.
So if anyone can be more specific about what rubbers from what VW van?
Zitat von: Fred in 2009-08-22, 19:52:06
Hello Maarten
You have to remove the high low shifting house ( 4 bolts )and a few circlips ,springs and distance bushes then you can pull out the shifting bar
The shifting lever from the 1e and 2e gear is only attacht to the shifting bar but will not fall down if you remove the shiftingbar.
It will stay ontop of the gearshiftlever and between the levers of the 3e / 4e and reverse gear.
Strange that you didnt try first and second gear because it only take's a few seconds and then you will know a lot more.
Fred
While removing the shift linkage I kind of accidently pushed it in 3rd and 4th while removing the nut of the bar ;D
Sorry, can't give you anything more specific than that URL/file I gave you earlier....and even though this donor-trick came from Australia, it would seem very weird if they had any different VW configurations/bushings than in Europe.
(as I posted earlier: 1995-2000 VW bus/transporter; the largest of two sizes of bushings)
So if you discover anything different or better, please post.
Don't think I have ever seen a posting about this on Terrangbil.net....even though they have more military donors at hand, I don't think they all would use that as a source, at least some would have started an new production batch.
(can't be that difficult to machine them; even with flexible PU-bushings in suspension systems you can do that apparently (making it much easier/cheaper for low-quantity batches, compared to pouring plastic in a pre-machined metal mold)
Maarten
I'm still waiting on my VW plastic-balljoint-bushings, a VW garage specialised in VW vans should be able to get me 4 of them. But their supplier didn't send them :(
So I'm still waiting for parts.
Will take pictures of them when I have 'em.
As for the rubber sealing bushes, I was able to get a piece of rubber hose that should have the right diameters. I only need to cut/saw/hack them in the right thickness.
Hmm....you mean any kind of 'straight' rubber hose?
Shouldn't it have at least *some* kind of 'bi-tapered' form, bulb-/bellow-shape?
Even though these joints don't suffer as much as other joints lower on the drive-train, a bad rubber gasket/cover would still more likely *trap* moisture/dirt, than prevent it from entering....just like a bad slide-joint bellow on the drive shaft would trap dirt/moisture, and cause more problems in the long run than not having any cover at all (which is actually the case with most vehicles, even most of 4x4's).
Btw, while I am/was pretty sure those bushings were out of stock with Volvo: are those rubber covers also out of stock already?
No idea whether any other brand is compatible....probably not from the same VW bus, is it?
Must say I haven't seen either component being asked about on Terrangbil.net either, in the last years (only on the English Yahoog mailinglist), but perhaps I overlooked it....might still be wise to post this thread there too....(if you are smart, you throw the English text also through http://translate.google.com, and add a Swedish text version as well).
(wonder how long it will take before web-forums start using an integrated translation/dual-language service?....:))
Maarten
As long as the wall thickness is big enough I guess some standard all-rubber hose should do the trick
As for the "tapering". The outside of the original is indeed tapered, but I don't think it is of much influence if it is not tapered.
The inside appears to be "tapered" too, but I have no idea what the original looks like, so it could be "tapered" because it has been trapped in the balljoint for I don't know how many years and took the shape of the ball.
I went to a Volvo specialist in Heerhugowaard when I was nearby. The Volvo number of the rubber sealing bushes was not known to their system. They wrote it down and said they would give it a try at Volvo Sweden, but I haven't heard from them since (maybey I should call them just to know if they were succesful) so I think they are unable to get them.
The VW specilist said VW doesn't use that kind of rubber bushes on their vans.
As for the plastic bushing, they don't have a Volvo part number in the parts catalog (partcatalogue15, page 3 and 4, numbers 28 and 37 are the rubber sealing bushes/washers, the plastic bushings that hold the ball aren't mentioned in the list.).
Just took some pics of the stuff I already have laying around, will upload them.
Maarten
#20
All the parts from the short link rod, this is the rod mounted directly to the top of the gearbox. The rubberhose that needs to be cut is seen on the left.
Different angle, should be enough hose. At least I can screw up a couple of times
Inside diameter is almost identical. Outside diameter is slightly larger.
Looks tapered on the inside.
Big side down, small side up.
The other way around.
The company that gave me this piece of hose also said it would be possible to make perfect fitting bushes, but that was going to cost me a lot of money for 4 pieces of rubber/silicone.
Maarten
picked up the VW bushings today.
VW partnumber is 701 711 166, they are from a VW T4 van.
michael
#22
I am very sceptical that this rubber will work.
As I see on your pics there are two different kinds of
sealings to protect the ball joints form dirt:
- On the front axle i.e. there is a rubber ring, but this ring is
a tube in itself or maybe an open tube formed to a ring, which
contains grease, may be. This litte tube can be compressed a
lot and gives the ball joint free space to move around. It will
keep water and dirt from diving away securely.
- On top of the gearbox it seems to be just rings of foam, to
keep away just dust, because the top of the gearbox should
allways be above the water following the instructions of 70 cm. This fom will give free way as well and clean the ball joint
like dish washing.
If you put in a massive ring of rubber it will
- limit the free angles to move aroung, even block it
- not protect the ball joint because it is not closed AND
there is no cleaning effect.
I would try to find a good piece of foam to put it there,
because this little ball joints have no mechanism to let
the rubber seals snap in as on the front axle. (may be,
I have not opened the steering mechanism...)
EDIT: After looking throug the complete thread I have to
add some words:
- The "open-ring-type" seal is to be seen on your pics at
the first connection in the gear mechanic.
- It may be possible to form a seal from rubber hose, but
it has to be ball shaped on the inside and on the outside
to give free way to the connector on the outside.
- On my gearbox both of this seals are gone, I think about
to put a piece of bicycle hose all over the joint and fill it with
grease
- If one of your ball joints is hard to move that will produce
problems with shifting gears, but only how easy it is, I can
not imagine how that affects the precision of the mechanic
For the clutch: My clutch wire/string was broken nearly direct
above the pedal (12 cm) and operated for 2 years on some
little wires left only. But gear shifting was easy until it was
broken completely in one moment. Only pressing the pedal
was against big resistance because the half brokens strings
were blocking in the hose.
As you described first the engine is slowing down in some
gears. That is forbidden behaviour! If the clucht is pressed
down and it is really open only the bearing of the clutch
should make a very little "shshshsh", and changing gears
MUST NOT affect the engine.
If the clutch is sorted out there is a big deal with something
inside the gearbox, if the gear lever mechanism in itself is
not broken or loose somewhere. Sorry...
good luck
michael
Maarten
like dish washing.
Just before starting to put a rubber ring on it I read your post.
We took another good look at the rings that where falling apart.
It could be indeed foam or leather.
I choose to put the rubber rings on them anyway, if that was a wise decision... only time can tell.
1 of the balljoints was quite loose and with the new VW bushing and the rubber ring it sits nice an tight. Not sure if that is because of the new bushing or because of the rubber ring.
For the rest, everything looks fine. Every balljoint can move enough, the rubber flexes enough. And if shifting goes to heavy I can just cut the rings away.
add some words:
grease
While searching for dust covers for balljoint a while back I found this picture:
According to that site they are made of Neoprene.
Depending on the size needed, they are very cheap (less then 1 euro) or very expensive (almost 13 euro) a piece.
If the rubber rings don't work as I want them to work, maybe I'll order some of those.
good luck
michael
The lever on the clutch housing is moving, so the wire isn't broken (at least not completely)
What was happening with the engine slowing down: It was running in neutral, press down the clutch all the way to the bottom and then try putting it in gear.
Some gears gave this grinding noise, the noise you get when trying to put a car in reverse while rolling slowly forward. Or when trying to change gears without the clutchpedale fully pressed. But some gears didn't give a grinding noise but where slowing down the engine. I think those gears are running "in sync" and are therefor not grinding but engaging and thus slowing down the engine. Like putting a car in gear and releasing the clutch (engine slows down).
Maarten
Put everything back on the TGB today.
Before trying anything I put the transferbox in neutral manually so everything could move freely.
First up was 3rd gear. No problems there.
Then 4th gear. No problems either.
Lets try 2nd then. hmm thats wierd... very difficult to find and engage...
But I also noticed a relay switching.
Tried 1st gear but that was also almost impossible to find.
Put it in "2nd" agian, asked my dad to check the rear lights. Yep reverse light was on.
After adjusting the reverse blocking mechanism so that fully to the left and then to the back was indeed second gear instead of somewhere between 2 and R or something.
Now 1st and 2nd are easy to find and engage again, and R is working like it should.
Next up where H and L, Little difficult to reach but are working ok.
So the shifting problems are over now, since I can engage every gear.
Now for the clutch problems...
Put it in N and H, handbrake on, normal brakes fully pressed. Fired up the engine (we had to convince the startmotor with a hammer that it actually had to do something). Pressed the clutch, tried to put it in gear. Not possible :(
Turned off the engine put it in gear, pressed the clutch, fired up the engine again. And I wasn't moving ???
Released the clutch slowly, engine started slowing down and then stopped. :o
Wait, what.... thats normal behaviour :D
Released all brakes, pressed the clutch, fired up the engine, put it in gear, gave a little gas released the clutch and I was moving ;D
Tried to reverse and that was also working normal.
So everything is working again.  8)
Finally I pulled the drainplug from the clutch housing and there was some brownish liquid coming out. Not much and looked like rust brown water. Definetly not oil, so probably because it hasn't been driven a lot last years moisture got into the clutch housing via a broken air hose on top of the clutch housing and got everything a little stuck.
Hopefully everything will be/stay ok after I replaced that hose and gave it a good drive.
rijo
bin heute durch Zufall über diese orange-farbenen Dinger gestolpert ....
Das Neue macht Sich ganz schick, oder?
Adele,
jochen
dirk
#26
Zitat von: rijo in 2010-09-06, 19:51:15
Adele,
jochen
zum glück braucht man nur eins und nicht 10 - weil sonst könnte man ziemlich ins stolpern geraten oder   ;D   ;D
GRUSS
dirk
tgb 11 . . .
tgb 1111 . . .
tgb 20 . . .
BV 202
tbc
rijo
Nöööö,
da braucht man schon 4Stück und da haut es einen dann richtig hin.
Gruß,
jochen
