24 Volt Fuel Pump
Begonnen von Anthony, 2009-09-29, 14:25:17
Anthony
Hello every one.  It has been some time since I last posted on these pages.  I hope that all are well and enjoying their Volvo's.
My Volvo C304 TGB13 has not been driven for a little while.  In that time the fuel pump does not deliver fuel.  I guess that the seals may have dried out perhaps.   I would like to discontinue relying on the mechanical pump and turn to electric.  Unfortunately 24 Volt pumps are not very common and I do not want to use a voltage dropper if I can get away with it.  I have looked at the Facet web site and noted several 24 Volt pumps.
http://www.fuelsystem.co.uk/
I realise that a low pressure pump is most suited for carburettors and the original mechanical pump is rated at 2.1 psi - 4.0 psi.  I am not sure about the volume.
Which ones might prove to be most suitable?
Most of these pumps have limited lift capability 0.3m - 0.6m.  this means that any of these pumps will need to be mounted close to the tank.  I have not yet investigated this but does any one know were the easiest place to put one might be.
they also list some Dura lift pumps.  Capable of lifting fuel at 3.0m dry.  This would allow it to be mounted within the engine compartment close to the original  Unfortunately the pressure, I think, might be too high at 11.0 psi - 5.9 psi.  Any of these pumps cold be routed via a Filter King and for any pumps that supplied too high a pressure can be fed through a pressure regulator.  Fuel King do a combined filter with regulator that can be adjusted it has a dial for reading the pressure.
http://www.fuelsystem.co.uk/Malpassi%20Fuel%20Pressure%20Regulators.pdf
I have also noticed that Thomas at the Pinze Shop has 24 Volt pumps, I have written to him for information about lift hight volume and psi but have not received a reply.
Does any one have any thoughts.  I hope that the links that I supplied are of interest.
Anthony
GB
TGB_11
The Pinzi-Shop does´nt exist since may 2009, sorry.
FWIW: I had the 'Red top' (170L/h) mounted between 300L extra tank & stock tank, with the added note that if my mechanical pump would ever fail, I could use that one instead.
However, I still wanted a spare mechanical pump with me....if only because an electrical pump is a safety risk, if not switched off automatically in case of an accident.
I also see no sense in having another essential electrical item, to drain your batteries in case your alternator got bad....I'd prefer only an 123-ignition draining, lasting for many many hours....;))
(btw, how much more does the original ignition consume?....can't be less, can it?)
(or is it the coil that consumes most of the energy?)
(which is still used with 123-ignition)
Don't add vulnerability to your vehicle, it will only make Murphy happy.
Fuel pump gaskets are dirt cheap btw, IIRC.
(even complete mechanical fuel pumps are!)
Hi Anthony,
are you sure that there ist not just some dirt in the fuelline ?
Have you checked the fuelline from the pump to the tank.
I had the same Problem. I took of the fuelline from the pump and was blowing through it. Than it was good.
Regards
Chris
#4
hi anthony,
good to have you back again!
i have switched from mechanical pump to electric, too, last year but discovered problems with that solution.
I mounted the fuel pump by the batteries on the left outside (TGB1314), new fuel lines, an truck fine filter and a normal prefilter with an one direction valve. i also removed the filter king, which is of no use for me anymore.
unfortuneately the heat of the engine caused the pump to fail after a short while, after cooling down it then works again. it is limited to 80°C.
after this experience, where my truck was standing on a public parking for over one month, i decided to switch back to the cheap and working mechanic pump.
i could still recommend the electric pump, as the engine was starting after one sec allways. its a hardy 18824v and automatically sets the fuel line to 0,35 bar pressure, selfregulated. no additional pressure regulator needed. fuel is pumped from dry at 1.2 metres.
best regards to the uk,
chris
Chris
Zitat von: Uli-RT in 2009-09-29, 18:21:31
Hi Anthony,
Regards
same with me. the mechanical pump was broken because of sand in the fuel lines. after cleaning everything and installing two filters everything was fine.
michael
hi, anthony,
before investing time and money into an additional
source of failures please try to check the original
parts.
The seals and membranes of the original pump are
very cheap an may be easyly changed. I have had
a prefilter directly behind the tank just before the
fuel line along the frame and never a problem.
Cleaning the whole lines is easy, too.
My car was sometimes just standing outside for 4 or
even for 6 month the last winter. The only thing to
do was to run the starter for about 2 minutes to have
enough fuel in the carburetors again.
If you try so be carefull to let the starter rest for 15
seconds after every 5 seconds of starting. May be
I have ruined my starter by starting for about 45
seconds in one attempt. It overheated and lost one
copper inlay from the collector, which blocked the
rotor and everything was nearly melted down from
shortage....
You can as well open up the fuel line on top to
insert some fuel to the carburetors manually and
put some start-pilot into the airbox, to let the engine
run a little bit from alone. That will bring enouth fuel
to the top again - I hope.
best wishes
michael
Chris
michael is right, i am using starter spray too - in cold conditions.
just use the hot-air intake right between the carbs, unplug the line and spray in some starter spray. the engine will do the rest.
hi, anthony,
parts.
shortage....
best wishes
michael
Perhaps the civil (12v) starters are technically different, but the one I abused many dozens of times in the most brutal way{*} still hasn't quit on me....
{*} another firefighter, rusty & tired, suffering from many problems simultaneously I guess, requiring (re-)starts many times on a trip
(pathetic little torque at low rpm, hence frequent engine stalling when driving off, even in 2nd gear; vapourlock (starting most problematic when hot), old spark plugs, bad fuel pump, plus last but not least: open headers (which did allow the original firebrigade to add a squirt of 'Liquid Start Boost' right from the driver's seat....:))
(and no, the engine hasn't quit yet either, from that abuse....:))
(it's my eardrums that will fail first, because they had to cut a section of body-panel away, near the front engine-hatch, to accommodate the open header....only a flap of vinyl separates it from the cabin....so you basically drive without engine-hatch, sound-wise....:))
Btw, when I mean slow starting, I am talking about at least 5 minutes of continuous cranking, each and every time....:))
(then slowly 1 cylinder springs to life, after another minute #2, and so on....:))))
(it doesn't even matter whether it has sit standing still for 1 hour, 1 day, or 3 years....same procedure as last year, James....:))
What you could also do, in very cold conditions, for a gasoline engine, is adding a fuel bypass with 72 octane fuel (you can create 72 octane by blending 50/50 regular high-octane gasoline with diesel)....much easier ignition.
(some old & tired Russian trucks can't even start on anything else in cold conditions....simply not enough compression to get startet on regular high-octane)
Have been tempting to create such a (temporarily) bypass by adding a 'anti-freeze-pump-injector' that is used for trucks with air-brakes; those allow squirting a limited amount of fluid into the line (and if they can do that in a line for air-pressure, they sure can do that in a line for fuel-pressure....)))
Anthony
Can you hear it............Brumm Brummm Brummmmm     ;D
Thank you every one, and all, for your kind advice and considerations.
I blew air into the tank with a ball pump via the petrol feed to the pump, all OK, blub, blub bubble.
I then disconnected the pipe from the filter carb side and with a large medical syringe forced fuel into the carburettors so filling the float bowls.  Reconnected the pipes and the brand new batteries turned it over, it coughed and spluttered.  I stopped and refilled the carbs, reconnected, turned her over and it started first time.  I revved it a little up and down and have now just left it running for a while.
Next thing on the agenda, is to have a look at the brakes as I have weeping cylinder front drivers side/left I fear!  My yearly MOT will need to be applied for, I let it run out. I will be able to put t back on the road once the MOT has been passed..
Anthony
GB
Anthony
That is a shame,TGB11.  i used to correspond a little with him but I did not hear for a while.  he has just replied thanking me for my enquiry and confirmed that he was not trading via the Pinz Shop.
Anthony
GB
Chris
hi anthony,
very nice- good job!
keep us updated on the brakes, too!
best regards,
chris
Anthony
Well it is going now  :)  I do not feel that an electric pump is a complication, on the contrary I feel that the mechanical pump is a liability and a pain!  I accept that what you say concerning an alternator malfunction, for what ever reason, yes, the pump would then drain the battery along with anything else that is running.
Ill have to see if I buy an electric pump as I have other expenses at the moment.   ::)
Anthony
GB
Anthony
It is very wonderful to have such a welcome and I am glad to be back!
thank you for supplying the link to the fuel pump www.hardi.de/verg.htm]hardy 18824v
It is interesting that it overheated and caused such problems or you!  I wonder if it was overstretched and possibly.  Located in the battery box do you think that it may have may not have had enough cooling air?  Ah not in the battery box but next to the engine, uhm.  Yes, perhaps the close proximity of the engine did it in.
Limited to 80 deg C, is that the pump??
Fast starting would be a pleasure.  It allays feels wrong to me, having to crank the engine so much after stopping, that is a real pain and inconvenient.  Putting all that additional strain on the battery and subjecting the starter to unnecessary heat.
The pump is self regulating you say? That is  good.
Do you think that it is immune from water if wading???
It is a pity that you felt it necessary to revert to mechanical.  many old Landrovers have changed toelectric.
chris
Anthony
GB
