Clutch oil drain plug
Begonnen von hdegroot, 2009-10-22, 10:19:27
hdegroot
#0
Hello, between the engine oil plug and transmission plug. There should be another bolt. For some strange reason mine doesn't have one there causing a small oil leak. Does anyone know witch size bolt should fit?
Thanks in advance
Fred
Hello
I dont know witch size bolt you need but your engine or gearbox is leaking oil .
If you install a bolt soon your clutchplate will be running in oil and you will have a big problem.
So if you don't use your volvo offroad and in deep water you better don't install this bolt.
If you do use the volvo in deep water then remove the bolt afterwords to avoid oil building up in the clutch housing
Greetings   Fred
Netherlands
Roge
Hello hille,
Your crankshaftseal is leeking. I had it to and replaced it. It's not that difficult. The plug, you can probebly get it at the volvo dealer.
Netherlands to, groeten Rogé
Only the Moose Knows
#3
I think that is the sealingring between Crankshaft and Clutch
Page 71  Part 33 ;)
