Moin aus Lübeck vom Explorer
Begonnen von Exmag, 2019-06-25, 20:12:06
Bär
Das Video ist interessant.
Den Berichten nach wäre es wahrscheinlich bei solchen Touren besser, wenn man sein Fahrzeug etwas mehr kennt.
Mich würde es auch freuen, wenn Martin mal auf einem Treffen vorbeischaut
Die Frage von Georg würde mich auch interessieren
Für Artgerechte Volvohaltung!
TGBwaldersee
#16
I have been following the EXPLORER Magazin Cnut 6x6 build from the beginning. i just purchased copies of the six back issues that details that cover the truck transformation plus the latest issue that shows the Iceland journey in print.
Like Georg, I also wonder about the transmission issue. Also, in the video (starting at 9:30), there is the brief section about losing the spare tire that was mounted on the rear door tire carrier. From the best I can make out, he seems to refer to the failure of some welding he had done on the carrier. As i am considering moving my spare from the cab roof of our 1975 TGB1314A to a carrier on the back door area, I want to avoid any unnecessary failures if possible.
Jim Molloy
Georg
#17
Hi Jim,
you are right, Cnut lost the spare tire because of a self made welding failing. If I remember correctly Cnut didn't have a spare tire carrier on the back door so Martin added one, similarly to the one some Volvos seem to have been outfitted from the factory.
I'm not sure this was a good idea, as Cnut has been upgraded to bigger rims and tires, so definitely more weight than the original one. Even for the standard wheel imho it is bad design, from my experience with other offroad vehicles it will never work in the long run, if you are driving offroad. It will over time damage the door or its hinges. Therefore I have outfitted my TLC with a spare wheel carrier/rear bumper combo.
Not yet sure how I will proceed with my current Volvo C306, currently it is (originally) sandwiched (horizontally) between the truck's bed and the exhaust silencers, were it is too hot and cramped, a bigger wheel won't fit in at all.
Best,
Georg
TGBwaldersee
George,
Thank you for the reply. I share your concern about placing the weight of a heavy tire and wheel on the door itself. I recently received some detailed photos from a member of the Volvo C303 and TGB Facebook page who had built a combined rear mounted ladder and swing out spare tire and double fuel can rack fixture for the back of his TGB131X truck. He used the top and bottom rear door hinge mounts on the body side of the hinge so the tire mount and the rear door are hinged separately. There is not extra weight on the rear door itelf. He also uses both of the rectangular box lifting sockets for additional support. Additionally, he chose to mount his spare tire far to the right of midline which would amplify the stresses on the box back wall and door hinge area when the rack was perpendicular to the rear of the truck body.
My primary reason for removing the spare from the roof of the cab is to place the spare closer to the ground if possible. Perhaps, I should refocus on coming up with a simple, compact. lightweight method of raising and lowering the spare to and from the original tire location in a very controlled manner.
Take care.
Jim
Exmag
Moin.
Entschuldigt, dass ich hier nur sporadisch vorbeischaue, gerade in der Saison nimmt das Heft doch viel Zeit in Anspruch.
Zu den technischen Hintergründen (die in einem Reisevideo immer schwer unterzubringen sind):
- Ja, ich gebe zu, ich kenne Cnut noch lange nicht so gut, wie man es sollte, aber ich freue mich jedes Mal, wenn man irgendwo ins Gespräch kommt und ich einen wertvollen Tipp bekomme. Wir müssen eben mehr in die Breite denken als in die Tiefe, da kommt manches eben dann schmerzhaft zu kurz.
- Soweit ich den Schadenshergang rekonstruieren kann, bin ich offensichtlich eine längere Zeit unwissentlich mit zugeschalteter Vorderachse gefahren, das VTG sieht ziemlich zerrupft aus.
- Vor Ort hatte ich das Schaltgetriebe in Verdacht, was sich aber hier in der Werkstatt als wohl unbegründet herausgestellt hat.
- Dass der Schaden am Ende eines Passes mit zuvor vielen engen Kurven und Kehren auftrat, passt zum VTG.
_
Zum Ersatzrad. Ich habe eigentlich nicht das Gefühl, dass die Tür unter dem Ersatzrad-Gewicht leidet, der Grundträger, den ich angefertigt habe, läuft zu den doch sehr massiven Scharnieren. Problem war eher an der Befestigung zum Rad. Dies konnte leicht schwingen und hat den eingeschweißten Bolzen aus der Trägerplatte herausgebrochen. Die Belastung war zu punktförmig, das musste ich nun etwas breiter abfangen.
Aber deshalb machen wir so etwas ja, um dazuzulernen und zu sehen, was passieren kann – und was nicht.
Nun geht es zur nächsten kleinen Runde durch den Süden Finnlands, mal sehen, wie es wird.
Martin
Lag dann an der Unterdruckdose am VTG kein Unterdruck an? Der Lappi hat eigentlich einen „Wegschalt-Allrad“ d.h. der Allrad ist erst mal drin und wird während der Fahrt dauerhaft über die Unterdruckdose ausgekuppelt. Liegt kein Unterdruck an ist die VA zugeschaltet. Bei den Achssperren ist es andersrum ;)
LG Raffi
Exmag
genau so war es. offensichtlich ein defekt in der Stromleitung, ich suche noch.
Tipp: wenn du eh schon die Peripherie checkst - es macht Sinn die automatische Allradzuschaltung bei Untersetzungsbetrieb zu brücken. Dann kannst du Pässe künftig prima in Low fahren - rauf und runter…
Hi es muß nicht an der Strom Leitung Ligen
Ich hatte ein Stecknadel großes Loch in der unterdruk Dose das hat den allrad zugeschaltet
Aber nicht ganz sondern nur ein wenig
Das war nicht lustig auf der Autobahn
Das System muß unbedingt dicht sein
Sonst geht der Alrad nicht raus Wen der unterdruk
Zu niedrig ist  das gilt bei der allrad zuschaltung
Unterdruk weck allrad dauerhaft drin!
Sperren Unterdruck da sperre drin!
Wie der raffi schon geschrieben hatte
Bär
auf der Abenteuer & Allrad haben Lars und ich Martin getroffen und ein paar Minuten Fachsimpeln können.
Nach ein paar Tipps und Lösungsansätzen hat Martin angefangen zu suchen. Sein Fazit war, dass das Magnetventil gar keinen Strom bekommt, mit einer Bypass Leitung jedoch schaltet.
Daher liegt die Vermutung nahe, das es Probleme Zwischen dem Kontakt am VTG, dem Ventil und dem Allradschalter gibt.
Ansatz für Martin daher, mal an den Sicherungen zu schauen, da der Strom komplett fehlt. Laut Schaltplan gibt es nur eine + Leitung (Nr. 25/73) welche zum Ventil führt. Sollte das nicht der Fehler sein ist es ein Masseproblem an mindestens einer der 3 Massepunkte.
Gruß Nils
Dängel
Gude zusammen,
Ich hätte jetzt den Bremsdruckschalter im Verdacht. Also der, der bei einer Vollbremsung den Allrad zuschaltet. Hat dieser eine Unterbrechung, ist der Allrad dauerhaft drin.
Martin: er sitzt über dem Bremspedal. Einfach Mal den Stecker trennen und die Leitungen verbinden. Dann müsste das Ventil schon schalten.
Netten Gruß ausm Odenwald
Janko
Ich lobe meinen L 3314 der ohne diese anfälligen Teile auskommt…
Ein Hebel: high, nur Hinterachse
               high, Allrad
               neutral, für Nebenantrieb, Winde
                low, Untersetzug und Allrad
Kann mit Gefühl während der Fahrt geschaltet werden…
Allrad sollte, ohne Mitteldifferential ,bei griffiger Fahrbahn und Kurven ausgeschaltet sein. Man merkt die Verspannung am Lenkrad…
Ich denke die Volvos sind für Untersetzung mit Allrad ausgelegt.
Nur Hinterachse mit Untersetzung wird zur Überlastung des Antriebsstranges führen …
Lg Franz
Servus Franz
Die Angst vor der Überbelastung des Antriebsstranges in Low ohne Allrad hatte ich auch mal - wurde allerdings von vielen Seiten dementiert. Ich nutze die untersetzung ohne Allrad laufend. Bei Passfahrten bergauf und vor allem bergab, beim Berganfahren, beim rangieren. Alles in allem fährt sich der Volvo damit kupplungs und bremsschonender. Dass ich nicht mit vollgas bergauf aus einer kurve beschleunige versteht sich von selbst  ;)
LG Raffi
Hallo Raffi
Mit Hausverstand fahren wird sich sicher ausgehen…
Schaltet der Allrad bei einer Vollbremsung bergab im Gebirge trotzdem dazu, wegen Überbremsung und abdriften der Hinterachse?
Für mich die beste Lösung hat mein Lindner Traktor Bj 1967 mit einer ZF Lamellenkupplung um den Allrad auch unter Last zu schalten.
LgFranz
Hallo Franz,
ja - die Allradzuschaltung beim Bremsen ist davon unberührt und bleibt bestehen... Das ist auch wichtig...
Liebe Grüße!
