aux output driving power
Begonnen von david.f, 2007-12-05, 23:40:35
david.f
i see on the tgb 13 that the second axle have ouput to drive the third axle.
i was wondering if we can adapte two axle like it , to have an auxiliary output power on the rear ?
i hope you understand me ...  :P
Anthony
If you are going to have an amphibious TGB 13 maybe the propeller could run off this PTO.  http://www.tgb-sidan.se/1c3prot.html   ;)
Some of these TGB have a PTO run off the transfer box to power winches and things.
Anthony
GB
You could, but only when you remove the stock fuel tank, otherwise things get cramped in there....:))
(only a very scarce few units exist with original side-mounted belly/truck tank (6x6 LWB civil pickup))
Also note that you need a complete diff unit from a donor vehicle; a non-drive-through/non-PTO-bogie diff can't be modified to fit this PTO.
My favorite application would be a driven/powered trailer, based on the rear section of a 6x6; either mechanically driven (rather complicated) or hydraulic, possibly using the T-case of that trailer-donor to switch in and out of trailer-drive....:))
Anthony
Ah just like the system that Landrover were going to adopt with the 101.  Unfortunately they dropped it because they were having too many accidents with the trailer unit pushing the towing vehicle causing the rig to Jack Knife  I understand that traction on very difficult ground was superb and the outfit that you propose would be even better! ;D  They had done this before with a series vehicle much earlier on. Ishould imagine, you may well know WJM, that other manufacturers probably have done this sort of thing as well.  I believe that the GB Army in Europe had powered trailers or semi trailers for some of their HGV Fleet and were employed in the Bosnian conflict.
WJM "( My favorite application would be a driven/powered trailer, based on the rear section of a 6x6; either mechanically driven (rather complicated) or hydraulic, possibly using the T-case of that trailer-donor to switch in and out of trailer-drive....:)) "
Anthony
GB
There exists at least 1 C2-series firefighter (crewcab/pickup) with a powered trailer, could be a factory configuration, not sure....:))
The powered semi-trailers in the UK-military were only a small batch I believe,  several years ago, brand/manufacturer/product-range no longer exists.
(one of their chief-designers contacted me some months ago....MultiDrive, IIRC)
Somewhere on the web there are video's (youtube?) showing both Pinzgauer's 718T (load-module) and this semi, driving at full speed.
Btw, note that the jack-knife problem would hardly exist with a 6x6 and rear bogie-drive, creating both weight and superb traction on those wheels....would never attempt this with a 4x4....:))
PS: even more months ago, I saw such MultiDrive semi truck for sale (no price mentioned)....quite inspiring, resulting in several brilliant camper-thoughts & -sketches....:))))
