Soon-to-be C306 owner and diesel questions
Begonnen von Korpisoturi, 2008-01-29, 18:50:55
Anthony
I would be very interested in seeing how you progressed.  I am curious about the company that you mentioned, do they do a lot of engine conversions? Who are they? Have they put any other diesel engines in a C303?
Anthony
GB
Korpisoturi
Well my progression is still very much in the theoretical level. I have found suppliers for the parts and materials I need as well as sources for engines and a shop to do my engine swap. So nothing visible has happened, but I have progressed. I also have a place to store and build my future Volvo in.
I don't want to give information about the company yet as I did not ask if I could do that. Dropping diesel engines into Volvos is not their main business, they repair big commercial trucks instead. The shop was full of trucks owned by big shipping companies etc. I will ask if I can advertise them here.
The 303 they are working on right now is the first diesel conversion for them if I understood right and they also modify it for pretty heavy expedition use. All previous ones have been gasoline engines for competition use. They do have three more Volvos in queue for diesel conversion though. By the way the person who builds the Volvos has five of his own. He has had Volvos since the early nineties. I guess (and hope!) he knows his stuff.
All based on the stock B30?
450-750hp sounds more like a big block V8....:))
All with the same 3.3L TD?
Shame that even customers who have the money for outsourcing the entire job never choose a Steyr....;((
Btw, all this is in Finland, right?
Korpisoturi
#33
No no, none based on the stock B30. I don't know exactly what sort of gasoline engines they use, but I'd also guess big block V8s.
Yep all their diesel conversions are the 3.3L TD+gearbox+transfer box and yes this is all in Finland and around Helsinki area. The guy asked me if I know how to get more of the engines because they need them all the time.
I guess they go for the Patrol engine because of easy spares and repairs. The Steyr is propably a wonderful engine, but I bet that spares are more readily available for the old Patrol in some rather remote countries.
I'd never choose a Nissan in that context, and even pre-1990 Land Cruiser diesels are useless in post-communist countries.
Note that both Russia and China *do* have Steyr license-production plants....;))
Willem (tried sourcing a J6 shock absorber, knowing it was nearly identical to Volvo, in a Russian Toyota dealership, and failed miserably....8-)) Jan
Anthony
#35
Its a pity hat they do not have experience of converting anything diesel other than the Nissan 3.3TD. This is the old indirect injection lump.  Having some one else do the job for you is ideal especially if they have plenty of knowledge of the Volvo C300 and it sounds as though they do.
Anthony
GB
Korpisoturi
Zitat von: Anthony in 2008-01-30, 19:03:20
The slower revving diesels do have a problem with translations unless very careful with matching to the correct box because of the overall low ratio of the final drive in the axles.  I think it has been suggested that a top gear ratio of approximately 0.8 - 0.7 is about right.
I have been digging around a bit and found out that the Patrol MQ 5-speed gearbox model FS5W81A has a final gear ratio of 0.825:1. The 4-speed box is 1:1.
There is also the Nissan Cabstar box with 5th gear ratio of 0.777:1.
All of the boxes above should fit the SD33(T) engines without problems.
I hope this helps someone. :)
