5speed overdrive conversion
Begonnen von wouterc, 2022-10-20, 14:49:19
wouterc
hello,
My name is Wouter and i'm from belgium. I stared to do my conversion to 5 speed with overdive for my c303.
i would like some slower engine rpm's for cruising for noise reduction and fuel consumption.
I will try to show what it takes to convert.
I started with a gearbox fom a c306. these have a 5 gear shift pattern. type: ZF S5-18/3
Then i also bought a gearbox from a maserati Biturbo these have a overdrive from 1-0.791
https://photos.app.goo.gl/hKERNCRMT1BrUgNM6
then i took them both appart.
https://photos.app.goo.gl/2rbExYjKB9Dxq7Lo9
the difference between the gearboxes are:
5the gear is an different place.
therefor they use a different syncromash lever witch hinges on the top instead of on the bottom.
https://photos.app.goo.gl/N3hGXo1tGxdpVyzM6
https://photos.app.goo.gl/9tyoPeBYpaQH7JgN8
The 3the and 4the of the c303 and 3 and 5the of the maserati has so be switched.
off course both axles and syncromashes has to be switched over. from the maserati box to the TBG box.
https://photos.app.goo.gl/eM7423Laz2Aff1za6
https://photos.app.goo.gl/TXsJ4dWZ525WQBHW6
I will try to use the front half of the gearbox from the masarati so that i dont have to redrill in the side of the case.
Also there is a spring loaded ball that keeps the switch levers in place. this ball is located on the other side of the case.
This has to cooperate with the 4-5the gear lever.
The ony thing that i have to do is resurface the top of the fron maserati box en cut out the peace on top to the gearlevers fit.
https://photos.app.goo.gl/cmDcscogAuKyHNNU7
https://photos.app.goo.gl/qVgSQsUwmNMM1wy68
there is room for surfacing the top part of the maserati front case.
https://photos.app.goo.gl/j6AH3wh3exxaeYHQ6
to be continued....
Wouter
