Conversion to diesel
Begonnen von dane, 2006-09-14, 21:48:57
dane
Hi there!
I am thinking about buying a C306 if I can get hold of one. I want to use it to do an expedition to africa. Michael says on his home page that the B30 engine may have problems with overheating in hot climates and requires high octane fuel, not necessarily a good idea for africa then. He goes on to suggest that perhaps one could do a conversion to a diesel engine. Maybe a Nissan Patrol engine. I have done a bit of research and found that Nissan made a 100hp straight 6 diesel motor (SD33) and the same motor with turbocharge (SD33T) 140hp. Does anyone have any idea how difficult such a conversion is to do?
Lastly, if over heating could be problem could it not be an idea to fit one of those fans that they use for racing to cool the engine more effectivley. As far as the fuel is concerned, if the fuel in africa is good enough to run a land rover (one of the most common petrol driven vehicles in africa) then surely it must be good enough to run a volvo ;)
Jason
Well, a c306 is defnetly not a bad choice. (owning one, it's easy to say so) I am not sure about how difficult it is, but i've seen several diesel modifications in the web. Mostly it's a nissan 3,5l engine.
If you take a look here: ebay .com item 220024929853 you'll find an interesting (but yet not beautiful) african prepared vehicle.
About running the normal engine... We're thinking ourselfes about taking our car to kenya. But you've to see, that this is a total differnet landscape then southafrica. Do you wan't to go into real desert? then normal petrol is properbly a bad idea, so it's getting way to hot and you get into danger, that the fuel could start to burn or just vanish by heat... (So you always have the feeling of sitting on a bomb) As well you will need more fuel then on diesel, which is defnetly a problem. If you choose to operate in more urban areas, high occtan fuel should'nt be that problem, therefor modern cars are getting more and more standard in those countries.
(link format changed by michael)
hi, Jason,
if you have a look at this thread and translate it with some tools there is an intense discussion about switching to diesel.
There are already some parts in english quoted from an other source.
Even if you will not understand everything (and I can not translate everything) you can find information about the names and types of engines that may be possible and informations about the standard gearing and power.
At all it is important to get a standard diesel - no turbo with an equivalent torque and power ratio at an equivalent rpm-level. In every other case you will have to change the gearbox, too, and may be the propeller shafts, too.
At all it is no easy task and some specialists who tried gave no feedback after a long time.
If you have a look to the link in the posting before you can see that it is possible. But it is no job out of a box - that guy may have changeg gearbox and propeller shafts.
regards
I answer here to this theme seperated from the main topic.
Until now we had 2 solutions against overheating of the B30a:
1. Install a seperate oil-cooler in front of the front axle and steering rods, there is a possible place above the cross girder under the main cooler.
2. exchange the original water cooler against a tropics one or one from construction vehicles. these coolers are twice the depth or more, which results in greater volume and greater area for cooling. The other dimensions (width and hight) stay unchanged. Most commercial vehicles delivered to tropic areas are fittet with tropic coolers.
I have a third idea:
2. install a second water cooler under the back, may be in the space for the PTO-winch. you have two possibilities to connect this cooler to the water circuit: the connections of the heater for the hold or the connecting points for the engine heating on the frame behind the muffler.
regards
dane
Thanks, like I said I don't have one yet, and I am beginning to think that if this vehicle were to be a serious option it would have to be converted to a diesel in some way. I will copy our chat though and use it if it becomes necessary. (by the way your english is perfectly understandable, no worries mate)
dane
Hi again just got a mail from someone that put a Mazda diesel engine into a C304. Here is a copy. I asked how difficult it was?
''The work was installed by a franchise garage from Motor and Diesel Engineers in Cambridgeshire, England. To date it has not let us down after the early modifications to the cooling system.
As far as I can remember the engine dropped in quite simply with the bell housing only being modified and the sump plate joint cut back to accommodate the front prop shaft. Everything else stayed the same. The cooling system I had to redesign after I found that the original Volvo expansion bottle was too low and with only an electric fan for cooling it was not good enough, so after blowing an oil cooler gasket in Morocco I had the original installer workshop fit a prop from the engine to a viscous fan behind the radiator, fix a truck expansion tank at high level behind the cab and to date I have crossed the Sahara with it and had the temperature needle up to 100C and no problems.  I retained the electrical fan on the front for extra cooling for long uphill sections in low gear.
The engine fitted in 1990 is a Mazda diesel naturally aspirated SL35 giving 99 hp at 3450 rpm and 174lb ft at 2000 rpm [figures from engine handbook] returning 7 kilometres per litre off road and 8 on tarmac. The exhaust goes up vertically with a stainless steel silencer and blows out over the side of the cab. The kick back I think I have resolved with a flexible coupling to the manifold. Two fuel tanks of 120 and 200 litres therefore give a range of over 2000 kilometres in extremes where fuel is scarce or expensive. Real test was in Sahara in 1992 when I had to travel over 1000 miles between fuel supplies on smaller tanks then, first opportunity I fitted bigger tanks and searched scrap yards for the optimum sizes to fit under cabin, removing my batteries inboard for security. Twin fuel filters and a water sedimentor filter were also connected with an electric pump between tanks. 3 separate battery circuits for starting and cabin power and for 220 volt outputs, the alternator was boosted with a Sterling electronic regulator to charge all three sets via a split charge unit.''
I don't know if you want to post it to the thread on 'motorumbau,
Cheers
Jason
