Puzzling door-locks & fan-speed settings....:))
Begonnen von WJM, 2007-05-17, 20:55:31
Verzeihung, wieder mal zu faul zum Uebersetzen, gerade auf die Mailingliste gepostet:
xxxxxxxxxxxxxx
Puzzling observations, triggered by inspecting another C306 firefighter:
While I can lock both right-side doors from the inside, I can't with
the left-side doors.
*If* there is some maniacal logic behind this side difference{*}, I
wonder whether it was opposite on Malasian and UK/RHS models....
{*} making it idiot-proof in military duty, against soldiers who
would otherwise lock either front or rear cabin with the key still
inside)
Onto an even larger maniacal puzzle:
Thusfar I thought that the fan-speed setting was factory 'twisted':
setting #1 means high speed, #2 means low speed.
Yet this C306 had the logical configuration, #1 low speed, #2 high
speed.
Of course, just to proof that there *were* really perverted maniacs
working at the Volvo assembly line at that time, the levers of 'golv
floor' and 'defroster' are mirrored in function (forgot which one is
correct).
(of course2, the heating valve and/or cable is stuck, as always)
(btw, does anyone know what the proper/factory angle of operation of
the dial should be?....is it indeed limited between the top and low
end of the 3cm 'bend arrow', left to the knob, or is that arrow just
an indication of direction, in which way to turn (many times))
(in my other C306, I had to turn many many times before the valve
would move (and then it would move all the way, of course, no
inbetween setting (that only happened when the cable finally snapped,
luckily....not too bad, at moderate ambient temperatures, in
combination with dual safari-windscreens, only a bit annoying at
standstill....:))
Willem (starts mistrusting knobs and dials everywhere now) Jan
hexoplast75
Hallo!
Ich habe heute mal meine Türschlösser genauer angesehen. Dabei ist mir aufgefallen, dass ich auf der rechten Fahrzeugseite die Tür von innen verriegeln kann, auf der linken Seite nicht. Zufall? Eine mit nicht nachvollziehbare Logik?
Beim Vergleich der Türverriegelungen fiel mir folgendes auf:
Auf der linken Fahrzeugseite war jeweils eine Schraube drin, die das Von-innen-verriegeln verhinderte. Ich habe sie entfernt. Falls alle Türen von innen zu wären, könnte ich noch durch die Hecktür rein. Die kann man garnicht von innen verriegeln.
Weiss jemand, wie man dieses Konservierungswachs entfernt? Bei den Mechaniken der vorderen Türen habe ich stark verklebte Teile gefunden, deshalb gingen die wohl auch immer so schwer/träge.
Servus
Benito
Auf der rechten Seite sind Passanten bzw. der Bürgersteig beim Parken. Auf der linken Seite kommt selten jemand vorbei, der aus Spaß mal die Tür aufmachen will.
Ein Wasserglas Universalverdünnung?
Kaltreiniger?
Danach eine Ladund WD40. Oder einfach nur als altes Hausmittel für Schlösser mit Gefriergefährdung: Graphitpulver?
Hartmut
Hallo!
da steckt schon Logik hinter: Die linke Tür schließt Du zu und die  Rechte verriegelst Du von innen, so kannst Du in Ruhe pennen oder sonst was machen. Die von innen verriegelte Tür bekommst Du aber nicht mehr von außen mit dem Schlüssel auf!
Hast Du nun zufällig den Riegel betätigt und die Tür fällt zu, sieht´s erst mal schlecht aus: Gepäckraum ausräumen und Bank umklappen, wenn die Trennwand noch drin ist, ist dann erst mal angesagt, wenn Du beide Türen von innen verriegeln kannst.
Hartmut
Hallo!
Hartmut
Du umschreibst zwar das eigentlich Problem, erwaehnst es aber nicht beim Namen: unabsichtliches zuschmeissen der linken Tuer(e), besonders weil die eben *nicht* per Schluessel wieder entriegelt werden koennen....
In dem Sinne hat Volvo das ganze schon ziemlich Foolproof/Deppensicher implementiert, nur haben die wohl nicht gerechnet mit unheimliche Situationen/Gegenden in dem man sehr gerne die (vorder)Tuere von innen verriegeln wuerde....
Eine Art Zwischenloesung waere das Ersetzen der Schraube mit etwas dass einen schweren, aber ueberwindbare Wiederstand erzeugt....damit der Faktor 'unabsichtlich' sehr weit weg liegt....also nie unabsichtlich beim Tuer zuschmeissen, aber trotzdem von innen bei verschlossenem Tuer.
(tausendfach Komplizierter waere die einzig andere Loesung: eine kuerze Rampe am Tuer-Rahmen, neben den Sitz, ueber dessen der innere Griff/Hebel, falls bei offener Tuer nach unten gedrueckt, angehoben wird, und sich daher automatisch wieder entriegelt....und per kuerze Rampe laesst sich der Griff/Hebel dann trotzdem noch herunterdruecken bei verschlossenem Tuer)
Willem (loves over-engineering small problems....8) Jan
dirk
. . . man könnte auch ein kleines riegelchen, dass man nur von innen bedienen kann als extravagantes sonderzubehör einbauen ;D ;D
aber warum sich mit den türen bemühen, wenn man die scheiben doch eh ohne probleme rausbnehmen kann  ??? ???
GRUSS
dirk
tgb 11 . . .
tgb 1111 . . .
tgb 20 . . .
BV 202
tbc
Das war auch meine bisherige Idee, bevor dieser Schraube erwaehnt wuerde....:))
Man unterscheide bitte Diebstahl/Einbruch von Diebstahl/Carjacking....;((
Hab das bei einem LKW-Doppelkabiner noch dreister implementiert gesehen, der hatte alle Tueren zugeschweisst, ausser der Tuer hinten rechts, gleich Einstieg zum hinteren Wohnteil....
(bei sehr grosse/luxe Wohnmobile ist das ja wenig anders, Einstieg duerch nur einen Wohn-Tuer, mittig Rechts....)
