gummibalg achse vorne
Begonnen von www.amerikaas.nl, 2008-10-09, 23:26:54
www.amerikaas.nl
the next thing i'm looking into is the "gummibalg" (volvo part nr 232353). Mine has a piece of rubber missing and i hope that someone can tell me how urgent this needs repairing. And if so where to find me a new "gummibalg". (Its the rubber folding connecting the axle between the 'spiders' after the power take off)
This Gummibalg is important to protect the sliding mechanism of the propeller shaft between the middle gear box and the front axle. That is needed every time the axle is moving up and down - that means at every little hole or step, at braking and starting and every move of the car.
If this mechanism is blocked by dirt or dust it may crack the middle gear box. We have seen that already...
You can build something from leather and put grease inside if nothing else is at hand.
But protect your propeller shaft!
good hope
Most 4x4's don't even have one, but because of the very short rear drive shaft in the SWB Volvo's (230cm, also 6x6), the angular differences with wheel travel are large, and so are the length differences in the slide-joint, so good lubrication is more important.
There is also a counter argument, or actually two:
1) If you *do* have a leak, water/dirt can accumulate inside, and cause rust without anybody noticing, until it is too late.
2) When you put grease into it, you can't see when it comes out, telling you when to stop.
(and too much grease is no good either, as it can cause 'hydro-lock', no air left inside to compress, resulting in high mechanical stress on both differential/U-joints and T-case, common problem on TLC J8-series (not sure why not on other/older series, perhaps higher road speed makes the inherent/preceeding vibrations more noticeable)
(in this context, one can consider removing the grease-nipple afterwards, put the suspension through maximum travel (up), and have the excess grease pushed out that way....then mount greasenipple again)
