Leaf springs
Begonnen von Mo, 2022-07-04, 16:24:27
Mo
Taking measurements of my vehicle (see https://www.c303.de/c303-forum/index.php?board=1;action=display;threadid=14803) I've realised that it leans towards the driver's side. The top of the front bumper on the passenger side is 94.5cm, on the driver's side it's only 91cm. Measurements between the stop plate and the hollow spring are similar, approx 5cm on the passenger side but only 3cm on the driver side.
I assume I have to replace my front springs. A set from Tatanka will cost at least £650 (€750) :o :'( Any alternate sources you would recommend? In a thread from 18 months ago (https://www.c303.de/c303-forum/index.php?board=35;action=display;threadid=14079) the German company https://www.federfachman.de is mentioned. Does anyone have any experience with them?
Thanks
Maurice
Mo
The parts catalogue lists only one number for the front springs indicating that the left and right springs are identical. So it's perhaps expected that my vehicle leans to the left as it probably often had a driver but no passenger. I also suspect that the batteries are heavier than the muffler and heater combined.
Questions:
  • I'm assuming that the lean to the left is a tired spring. Could it be something else? Rusted springs or bad bushes for example?
  • In this earlier thread Tegebe mentions he visited a "federbauer". I assume that's not actually a farmer ;D but a manufacturer/supplier. There are of course leaf spring manufacturers here in the UK, and I found one (http://www.owensprings.co.uk/) that's close to where I live. UK manufacturers likely won't have a problem to make the imperial size springs used by the Volvo but they won't have the specification. Can they obtain all the info they need by examining the springs while they're attached to the vehicle or do they need to be removed first? Alternately, does anyone have the original specification for a C303?
  • New springs sit up to 30mm higher, Tatanka mentions that their springs sit 12mm higher (presumably when settled). Meanwhile replacement Koni dampers are 7mm shorter. Those of you that have already fitted non-OEM springs, have you had any problems with your dampers?
  • Are there any implications if I replace, for example, the front but not the rear springs?
Thanks
Maurice
it's no problem any feather builder can replicate the feathers. it is the problem the spring steel in the to procure the width required for the volvo past I think it's 75mm. that's why no one builds the springs in all of Germany it is a special size nobody orders 1000kg the material that he only needs once for 2 leaf spring packages at 100 it would look different that's how it is in germany.
Mo
Aha! I realised that the spring specifications are in the workshop manual. So a local manufacturer should be able to construct springs that are both the correct size and the correct strength without too much difficulty.
Yes. Each leaf is 3 inches wide (76mm) and 9/32 inch thick (7mm). I'm confident that any UK spring builder serving the vintage car market will have such material available as this size was once common here. So this may be a cost-effective solution for all of us 8)
I will contact the local manufacturer just as soon a I've rebuilt my wiper motors (it's illegal to drive without wipers) and update everyone here with my findings.
Thanks
Maurice
Mo
Can anyone tell me the spring bush size/measurements (for a 4x4)? I'd rather not unbolt a spring just to take measurements.
Also, is it usual to use new spring bolts when replacing springs?
Thanks
Maurice
